oil leak,need som help here again
i have some oil leaking in the front of the engine, do anybody know what gasket i need,or do anybody have the gasket scheme, or engine parts scheme,drawings of the engine, the car is still a w211 220 cdi 2008
Lars
Lars
clean everything off with BRAKE CLEAN and re-check in future. My guess though would be your turbo inlet seals but I can't exactly tell from your photos....
thank you,for reply, i have cleaned them parts, but i dont know where the oil is comming from, where is the turbo inlet seal?, how can i take a picture so you can see better??
Lars
Lars
To find a leak of oil, water, or any fluid: first thoroughly clean the engine and search for source using a bright flash light. If you have trouble finding the source, re-clean and keep looking.
Sounds like you have a leaky timing case seal ring----part 023 997 84 47 You will spend loads of nights and weekends replacing that baby!!
Nag nag nag all you want, all I can say is, I sure hope the seal is not leaking and you just spilled some fish oil on the engine after a night out with the girls!!
i was the brake vacuum pump that was leak,i changed it some weeks ago, and now its clean,and no more leaks i the front of the engine, the pump was also a little damaged where it is mounted on the camshaft
