E-Class (W211) 2003-2009
Gas smell, engine no start, engine continute to crank
Old Jan 7, 2016 | 10:26 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Originally Posted by bnaddaf
My 2005 Mercedes E320 / W211 went to Aamco for a check engine light test and came out dead. In short, they took the transmission fluid out and put it in my engine. After 30 miles of driving, it died and wouldn't run again.
Towed to a new mechanic who found no fluid in the transmission, while the engine was overfilled with around 3 to 5 quarts of transmission fluid. Now, the starter turns / cranks the engine, but the engine doesn't start / run.
After spending $900 with the new mechanic, I'm faced with having to fix it myself. I towed it home today and the first thing I did was to drain the oil by 5 quarts using a pump. The engine still doesn't start.
The shop changed the crankshaft sensor, the transmission plug and valve body conductor plate to fix the car, but it doesn't start for testing test the transmission that is supposedly fixed.
The fuel pump runs, but there's no pressure at the gauge. Does anybody know if there's a vacuum line or valve that could be blocked or broken by the overfill that could cause this? The mechanic didn't find any error codes relevant to the no start. Your help or advice on how to further diagnose and repair my car would be greatly appreciated. https://mbworld.org/forums/images/smilies/nixweiss.gif
law suit. you paid him-he effed your issh up and now its back at your house?????? Should of never left the shop to begin with. You pretty much wiped his hands clean of the situation by leaving his lot. Your plugs, injectors, ect are all saturated in trans fluid..... I would start by checking those. Simplistic thing to check in my opinion.
Old May 3, 2017 | 06:10 PM
Marxs's Avatar
c220 cdi w203, c200 w202, ML 320 w163
Hi
I had the same problem with a w202 c200.
Suddenly ran rough after refuelling, bad rotten egg smell.
Thought it was bad fuel or maf, I replaced the Maf no difference. Checked the spark plugs, all good. Then checked the ignition coil, and one of these had failed.
Replaced it, runs like new.
Hope this helps someone.
Cheers Mark
