E-Class (W211) 2003-2009
clutch type limited slip differential
Old 12-10-2015, 06:12 PM
Steven Sloma's Avatar
2006 E500
My stock 2006 E500 doesn't handle well in the twisties. I would like to find a clutch type limited slip differential that will lock under high loads like I had on my old Corvette RR car. The car just can't be steered with rear power as stock configured and won't drift. Any thoughts? I did see ads for a Quaife? brand differential but the mfg. says it doesn't lock.
Old 12-10-2015, 06:42 PM
kajtek1's Avatar
Received 1,728 Likes on 1,378 Posts
1922 Ford Model T / no OBD
2 different traction system working independently on the same axle?
I wonder what are the chances they will work against each other and you end on tow truck?
Old 12-10-2015, 06:51 PM
2006 E500
limited slip
I am guessing I can disable the existing traction control system as it applies braking to control the car when charging to and out from the apex. Instead of allowing a drift it just slows the car down.
Old 12-10-2015, 08:27 PM
kajtek1's Avatar
I am guessing too.
If you ever do that, post the results.
Sounds exiting.
Old 12-10-2015, 10:51 PM
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
Kleeman makes an LSD for MB's. It's not cheap though.
Old 12-11-2015, 01:46 PM
2006 E500
I guess the best answer is buy an E63 s which comes with a limited slip differential. the Kleeman would probably set me back less.
Quick Reply: clutch type limited slip differential
