E-Class (W211) 2003-2009
Interior color Code: Twin/ ARTICO Grey MB TEX code help needed please.
Old Dec 21, 2015 | 12:44 PM
kkanuck's Avatar
'06 E320 CDI, '04 Sprinter 316 CDI
Hello,
I am trying to determine if the Artico Grey changed in colors between 2006 & 2007.
I have a seat that is messed up and found what appears to be the same, but from a 2007 model year (facelift) versus my 2006 (prefacelift)
I have verified by VIN on the Russian Vin check site that both vehicles have the Artico Grey MX Tex.....
However, they have different code numbers.
My 2006 has the following:
Interior color 138A MB TEX-LEATHER, TWIN/ARTICO - GRAY
SA Code
130A MB TEX-LEATHER, TWIN/ARTICO
Where the 2007 in question I am trying to verify if a match has the following:
Interior color 148A MB TEX-LEATHER, TWIN/ARTICO - GRAY
140A MB TEX-LEATHER, TWIN/ARTICO
Does anyone by chance have any expertise in this to know if the color is same, just code number changed between model numbers, or is it different?
I do not want to buy it if not a perfect match and it would be an online purchase so I am unable to compare in front of my eyes only via pictures which can be deceiving.
Any help would be greatly appreciated.
Thank you
Old Feb 13, 2019 | 02:06 PM
chris1978's Avatar
05 mercedes e320 cdi
Color code
Originally Posted by kkanuck
Hello,
SA Code
Thank you
Hi there, did you ever find an answer to your color issue? I have the exact same question. I suspect it is the same as MB has a history of changing the names and code of the same color. Thanks
Old Feb 13, 2019 | 03:48 PM
konigstiger's Avatar
'71 Pinto
VIN and seat part(s) of interest I will provide # with color code extension.
Old Feb 15, 2019 | 01:20 PM
chris1978's Avatar
Konig,
my question is can front seats from an 09 e350 fit my 05 e320 cdi. The interior color of the 09 is called 148A twin/artico and my 05 is 138A twin/artico. Thinking the color is most likely the same. It looks like it from pics. Still, will they fit and work in my 05? The donor car is 09 Mercedes e350 (WDBUF56X29B362123). Recipient car is my 05 e320 cdi(WDBUF26J05A683524). Any help is greatly appreciated.
thanks
Old Feb 15, 2019 | 03:02 PM
'71 Pinto
As it concerns interior color 09 = 7F40 Palm Gray, 05 = 7F95 Palm Gray should match. Seat adjuster part #s match however, 09 has heated function. They’ll fit of course but most likely not plug & play. Hopefully someone who did retrofit will comment.
Old Feb 15, 2019 | 09:58 PM
chris1978's Avatar
W211 seat interchange
Konigstiger,
Hey thanks for for looking that up for me. So when you say it will fit but likely not plug and play, do you mean the heated seat function? Or all the power functions? We had an 06 with 425k that had the heated seats but alas, a jackass did pull out in front of my better half and did total that beautiful CDI. The 05 sadly does not have that function to my wife's eternal regret. I on the other hand can live without that opulence 😉. I just wouldn't want to have to retrofit the seats to make the other power functions work ie up down back forward and the like ya know?
thanks again, you guys are literally the best
Chris
Old Feb 16, 2019 | 10:36 AM
'71 Pinto
Haven't gone through the attachments but here's part capture to compare CUs - weight sensing, seat, etc.
File Type: pdf
File Type: pdf
Old Apr 10, 2019 | 05:29 AM
efonz's Avatar
2005 E500 AMG Appearance Pkg
Konigstiger, awhile ago you were nice enough to provide me with my VIN data card, it states my interior color code as 838A, do you happen to know if 7F40 is the same color from a different year?
Trying to replace driver seat cushion, 7F40 looks like its the same color grey - not sure though.
Old Apr 10, 2019 | 01:44 PM
'71 Pinto
WDBUF70J35A755211 driver seat cover is 21191083927F40.
