timing chain tensioner sound"with video"
could this be the chain tensioner,that is making this sound??
i have tryed without the serpentine belt, and the sound is still there its a w211 220cdi 2008,with 430,000km |
i have now changed the chain tensioner,and the sound is still there, i also have tryed without the serpentine belt, and the sound still is there, am waiting for the harmonic balancer belt drive wheel..what you think??
I hear a bit of metallic rattling. Is that the sound? How old is the belt running gear? Have you tried an automotive stethoscope? Does turning the AC have any impact? Does it vary with engine speed?
thank you for reply,i have tryed without the belt, and the sound is still there,the strange thing,is that its more sound, if i turn on the heating inside the car, what is the belt running gear??
By running gear I meant the belt, pulleys etc. On some models there are bushings that wear on the air box that can cause a rattling sound.
More sound with the heat turned on? Is that the case with heat on and AC is in off position? |
Originally Posted by Tschuss_Bill
(Post 6704711)
Did you check for chain stretch?
Originally Posted by samaritrey
(Post 6706051)
what do i need to remove?? |
