WIS help,for the chain tensioner replacement
can somebody with the WIS please tell me how to remove the chain tensioner,and innstall it, i have read that i need to have it in the tdc, and then remove it, and innstall it
my win is:WDB2112081B281033
and its a 220cdi
2008
and its a 220cdi
2008
Very streight forward once you have moved the crank shaft in the clockwise direction to the TDC---then remove the air filter housing--then remove the chain tensioner--the suggestion is to also replace the seal ring and the torque is 80Nm--that's it!!
FYI you have a 646.82
Be watchful of spam and mis information!!
