E-Class (W211) 2003-2009
Breaks squealing in reverse?
Old Feb 12, 2016 | 12:52 AM
sneerz's Avatar
2008 E550
Hi my breaks squeal in the morning when going in reverse and breaking. The sound is very loud and really makes me wonder why its happening. It also sometimes happens during the day after I've driven it for a while when I try to reverse. I think it has something to do with tension built up in park to reverse or something, because when it moves faster in drive (without pressing the gas) and I try to break, the sound is very loud. I hope you guys know what I'm talking about, its kind of hard to explain. So my mechanic says the breaks and rotors are fine and he doesn't know why this is happening. Honestly it seems pretty strange that a mechanic doesn't know what is wrong but do you guys have any idea as to why this is happening? Thanks.
Old Feb 12, 2016 | 10:10 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
When we know general principals what can make brakes squeal, often the real reasons are very hard to figure out.
Everybody is advising putting silencing paste and where to apply it is whole science.
For last 10 years I am putting all the pads with no silencers and have no squeals.
I just make sure everything is clean and in CA we don't have rust issues.
What pads you have? Often changing pads makes the solution and I just took off MB pads with 50% wear to put dustless Akebonos.
Old Feb 12, 2016 | 11:24 AM
Tschuss_Bill's Avatar
2005 E320 CDI
+1 for Akebono. Shop around for these, I've seen a pretty wide spread in pricing.
Old Feb 12, 2016 | 12:59 PM
Stuttgarten's Avatar
'13 E350 . M276
After I got my car, I installed OEM brake pads, and they immediately started making noise when brakes were applied. I had the car checked by 2 mechanics and they could not figure it out. I decided to replace the pads with a new OEM set, but the problem continued. So, I decided to ignore it. I was also wanting to get dust free pads, so the recommendation was to go with the Akebonos. Once I had those installed the dust went away and the noise went away. I'm all for the Akebonos! They solved my problem.
Old Feb 12, 2016 | 01:11 PM
kajtek1's Avatar
I recall you had some rotor flaws Al ?
Do you still have the same rotors and Akebono gave smooth braking?
Old Feb 12, 2016 | 04:32 PM
'13 E350 . M276
It turned out to be a problem with pads. Rotors are the same and the noise has disappeared. I swear by the Akebonos
Old Feb 12, 2016 | 04:41 PM
'13 E350 . M276
Originally Posted by Plutoe
These guys are two less learned peas in a pod, can you imagine a statement like "the dust went away" here we go again non ware brake pads-get serious we like most BW daters dident fall off the water mellon truck yesterday--you both need to study up on brake pad formulations!!
You rat head, you need to tone it down, man! This is not your mom's corner store. Do you get a kick out of thinking you're ridiculing people. Everybody has their own unique experience with their cars, and all they're doing is sharing it with other forum members. If you don't like something somebody wrote, just shut up! If I wrote Akebono pads took care of my noise problem, who do you think you are to say otherwise. Leave that bottle alone, drinking and writing on the forum is toxic for your corpus callosum, it makes you sound like a third grader! Go learn some proper English first. Get a life guy!
Old Feb 12, 2016 | 08:03 PM
kajtek1's Avatar
I don't think teenagers can buy bottle in Florida.
On the other hand, nobody ask for ID while selling drugs
Old Feb 13, 2016 | 01:35 AM
LemonSqueezy's Avatar
14 550 sedan
It is true that Akebonos give pretty smooth braking while also releasing less brake dust but I guarantee you that it does not have the same stopping power as OEM pads. I could immediately tell the difference when I switched from OEM. Also if your mechanic cannot diagnose a simple brake squeal problem I don't think you should keep going to him anymore!
Old Feb 13, 2016 | 08:49 AM
marc hanna's Avatar
2023 GLK250, 1987 560SL
Just find a brand of rotors and pads and stick with that. It's pretty simple.
Different vehicles, different weights, different size brakes . . . you can get a very different experience with the same brand on two different vehicles.
Funny enough, even a heavy coat of calliper paint can reduce squeal . . . because it dampens the ringing on casting.
Old Feb 13, 2016 | 10:37 AM
kajtek1's Avatar
I did not notice any difference and put Akebonos on 2 of MB. Still can lock the wheels and give BAS some workout.
One member some time ago claim to measure the difference and he come with 3% difference. I am skeptic about the number as those tests have big margin errors - bigger than 3%.
Anyway, if I can lock the wheels any time I want, the brakes are good for me.
Just 3 days ago we had panic stop on freeway, when the car in front of me turn into the shoulder in fear of rear ending guy in front, the car behind me went on the shoulder as well, when my wagon stop in straight line with space to spare.
Old Feb 13, 2016 | 08:27 PM
14 550 sedan
The 'bite' from OEM pads just felt stronger IMO but the Akebonos are miles cheaper and still provide great stopping power so they're ey-oh-kay in my book.
