E-Class (W211) 2003-2009
Power Passenger Seat Stuck
Old May 10, 2016 | 09:09 AM
nishboo's Avatar
W124, W126, W140, W220, W222, R129
Hey guys. Bought a 2007 E350 recently. The car is super clean, and super nice, but the power passenger seat doesn't work correctly.
When I try to move it forward or back, it starts to move only on the right rail. The left rail does not work at all. It starts to pivot a bit on that rail. I put Silicone/Lube to break it off in case it was stuck and no change.
I did check the track, and don't see anything that would obstruct it. I was thinking of pulling out the rails, but when I went behind the seat, the bolts are covered by the seat and of course, I cant move it forward.
The rest of the seat moves exactly as it should. Any ideas?
Old May 10, 2016 | 10:16 AM
nishboo's Avatar
Its physically stuck, wanted to see if anybody knew how to remove it? any hints? Is there a separate motor for the left side that may not be working. Any specific access point underneath which will help me lube the track or clean the track better.. etc
Old May 10, 2016 | 12:46 PM
nishboo's Avatar
Sorry, for clarification, I meant, is there two motors, one for right rail and one for the left rail of the passenger seat.
Old May 10, 2016 | 05:13 PM
konigstiger's Avatar
'71 Pinto
One motor for the fore and aft motion, see attachment for seat removal.
File Type: pdf
Old May 10, 2016 | 05:14 PM
nishboo's Avatar
My problem is I cant reach or unbolt #2 in the diagram above. Those bolts are covered by the rails. Is there another way to do this?
Old May 10, 2016 | 05:16 PM
'71 Pinto
Can you raise seat to highest position and inspect underneath?
Old May 10, 2016 | 05:18 PM
nishboo's Avatar
I can, but it seems like the rails have a covering going over them.
Old May 10, 2016 | 05:50 PM
'71 Pinto
http://www.ebay.com/itm/2007-2009-ME...-/191756272236 click on original listing to view photos this will give you an understanding how motor interacts with frame, may not be rail.
Old May 19, 2016 | 09:22 AM
nishboo's Avatar
I spoke to my mercedes tech, and he mentioned that the issue may not be a motor or blockage, but more likely a broken frame. Is that a common thing?
Old May 19, 2016 | 04:56 PM
'71 Pinto
Remove front bolts, then see if you can somehow turn rod to each side so seat manually moves forward to access rear bolts. Mouse over post 10 link to see rod inside rail.
