2006 E320 CDI ESC problem - steering angle sensor and Sensotronic Brake Control
I use an iCarsoft i980 code reader.
Last year it started throwing an 4D41 "Check component N49 (steering angle sensor) error code. I purchased a new (oem) steering angle sensor and installed it myself using some excellent YouTube instructions some kind soul provided. After the installation, I did the 5 turns full left and right that is supposed to calibrate the sensor after a new install. Nevertheless, I continue to get the same fault code.
If I go into the current status readings (before I clear the fault code, with ignition on and engine off and code reader on line) I get:
Rotational speed: -0.47 degrees/s (with minor variation, even though no one is turning the steering wheel)
Lateral acceleration: 0.41 m/s^2 (which is ridiculous as the steering wheel and car are stationary)
N49 (steering angle sensor) 0 degrees - and that changes if you turn the wheel, going to a ridiculous 6549.60 degrees if you turn the steering wheel slightly CCW off center!
N49 (steering angle sensor) OK - even though the 4D41 Check component N49 (steering angle sensor) fault code is registering
My power supply reading is (engine off) 12.48 v on the code reader
Today I noted the following in the Sensotronic brake control section on the code reader:
C225C Event ABD control
C25D5 Hydraulics fault
Malfunction in pressure supply
Anyone have any idea what might be wrong here. The car drives fine, except I get the take car to workshop error message soon after I start driving it and clearing the error code does not last.
I changed the steering sensor and the darned thing does not seem to care.
One thing, both batteries are new as of 1.5 years ago and both are CGM type.
Help?
Dealer wanted $1500 to replace the steering angle sensor ($150 part), and it took me about 4 yours to do the job as a novice (I could do it a second time in under 2 h), so even at $150 an hour, I don't see $1500 cost in their doing the repair so I wonder if they were not thinking something else was really wrong.
- nopcbs
Beside steering sensor error, you have yaw sensor error. Are you positive your scanner is erasing the codes? It is common that lower end scanners can erase pending code, but will not erase hard codes from permanent memory.
Can you read SBC push count? Just because car drives fine, it might not prevent the computer to force you for new SBC pump by putting it in limp mode.
Per reports - it take about 2 months.
Don't even get me started on dealer charges.
Good luck.
My i980 removes error codes from the memory that it reads from. As for a permanent history database, I don't know, but that should not cause any current operational problems as it is just a history database.
Not sure if I can access the SBC (pedal) push count with my reader. Is there another way to access the count?
In any case, I should have nothing near the 300,000 counts that people talk about. The car sits idle half of each year and only has about 40,000 miles on it, anyway.
Thanks!
- Geo
Good luck.
Yes, clean all the plugs you can think about, including those going into modules.
but your sbc will also cause these malfunctions..... i would chase sbc issue first as that is going to eliminate concern about esp.... if sbc is faulty esp as well will be faulty. considering you have new scm i find it hard to believe new one is bad.... possible but not likely...
your dealer is insane.... i think its like 2.5 hrs labor to replace scm with erasing dtcs and all that good stuff.
The only really weird reading is the 6,xxx degrees steering angle reading when I turn the steering wheel a few degrees left of center. Turning it to the right of center gives correct angle readings. I also get very small/unsteady rotational speeds when standing still and small/unsteady lateral accelerations when standing still.
I also get errors on the auxiliary battery (defective or not installed) and auxiliary battery relay defective or signal wire not present. That battery is only less than 2-years old and mostly sits on a battery maintainer as I don't drive the car in summer. Actual auxiliary battery voltage is 12.21v, which should be fine. The average auxiliary battery voltage is 13.03v.
I drove the car all last winter with this goofiness going on and it drove normally. I thought the problem was just a bad steering angle sensor, so I replaced that and the ESP error still occurs.
I think the SBC error that I cleared and that did not come back was just leftover from before I replaced the batteries (both) last year.
I was starting to think that my problem is a bad yaw sensor, and maybe it is as those wobbling rotational speed and lateral acceleration readings when still make no sense. That HUGE steering angle when I turn the wheel left makes zero sense, unless the new steering angle sensor is bad.
Appreciate suggestions.
- geo
- geo
Thanks!
nopcbs
The ESC malfunction dash panel message came right back as soon as I drove the car.
I went looking with the i980 again and the only faults were for the N49 steering angle sensor. Plus, I am still getting that crazy 6,xxx degrees steering angle when I turn the wheel left of center. Right reads correct angle, as does on center.
I wonder if the steering angle sensor is just "bad:, even though it is new.
Car drives OK, by the way, other than showing the ESC malfunction message.
What a pain!
- Nopcbs
I am learning that car reliability is the biggest luxury feature you can have and some "luxury" brands have it in spades, while others simply do not.
- nopcbs
Good luck.
But I remember some issue required driving sequence to initialize sensors correctly, just can't say is it needed after new SAS installed. SDS would tell for sure, I doubt carsoft won't but you may see if there is any options for initialize sensor...
To be sure; is your steering wheel dead straight now? Even pole length offset may trigger sensor fault.
I'm working on a 2006 E350 with 4CF1 (yaw sensor) and 4D41 (SAS) errors. Yaw sensor and brake switch have been replaced with no change. I'd like to have a better confidence level that replacing the SAS will actually solve the problem (no cruise control).
Local shop wants $100 just to read codes!
May be as simple as clearing stored fault codes with “SDS” but given unique readings may also need to initialize steering angle sensor: Information Communication/SCM – Steering Column Module/Initial Start Up.
