E-Class (W211) 2003-2009
Reduced braking power start engine?
Old Jan 21, 2017 | 11:49 PM
cMazara's Avatar
w211 03'
I have the red message going on this days, and it feels like the braking is more direct, not soft as usual.. When they changed the sbc unit, they also changed the pressure accumulator??
Old Jan 21, 2017 | 11:51 PM
cMazara's Avatar
w211 03'
check fuses just in case.. Also did you managed to check the voltage on the old unnit??
Old Jan 23, 2017 | 03:18 PM
jho9393's Avatar
2006 E350
Ok so it turned out there were some issues with the grounding so mechanic said he updated it, not sure what that means though. He also said it needed a new some kind of hose? So once it's installed and bled with the new hose he thinks it will be working as it should now. I'll get the car back by the end of the day so we shall see..
Old Jan 24, 2017 | 03:06 AM
jho9393's Avatar
2006 E350
So it was a brake suction hose they had to replace and after bleeding and flushing brake fluid, everything seems to be in order. The brakes are stiff and more responsive and best of all I don't have to turn the ignition 20 times to remove the red warning message. Total cost including part and labor came out to around $1500, which seems to be a fair price.
Old Jan 24, 2017 | 09:54 AM
cMazara's Avatar
w211 03'
Can you post a pic of the mentioned hose please.
I have the same message and will try everything before buying an sbc unit.
Old Jan 24, 2017 | 12:00 PM
konigstiger's Avatar
'71 Pinto
If attached recalls are applicable to your VIN, check with local MB dealer to confirm they were completed by having them check VMI. If not, repair is free. Bulletin covers suction hose, don't think this is your problem though.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 24, 2017 | 02:25 PM
  #32
jho9393's Avatar
2006 E350
I'm not sure where exactly it is located, but I have the part number for it and its 2114208826.
http://www.mbpartsworld.com/p/Merced...114208826.html
Old Dec 17, 2019 | 05:55 AM
  #33
Ilajtai's Avatar
W211 e220 cdi
Totally useful comment
Originally Posted by kajtek1
Check Codes.
My guess is you have battery going bad, but that is what code will tell for sure.
Thank you Sir, saved me from a mental breakdow and almost a whole day. Battery went dead, bought new one, changed, car like new.
Old Dec 17, 2019 | 01:06 PM
  #34
kajtek1's Avatar
1922 Ford Model T / no OBD
Glad to see advice given 3 years ago still has good value, regardless forum troll trying to hijack the dispute.
Old Jan 24, 2024 | 03:51 AM
  #35
inthestu's Avatar
2006 E320 CDI
Reduced Braking Power Start Engine but won’t start
Originally Posted by jho9393
Hi I have a 06 E350 with nearly 200k miles on it. Every now and then I would get this message "Reduced braking power start engine" and when I turn it on it would then say "Reduced braking power visit workshop." Upon restarting the car (sometimes it takes more than once) the message would go away and the car seems to drive fine. But when I drove with the message on it had the ABS error sign on and the brakes seemed a little off, and didnt feel like it was grabbing it. What might be the problem here?
Hi guys I have a 2006 e320 cdi. just had the battery replaced and didn’t drive it for 2 days now this prompt shows up and the engine won’t turn over. coldest it gets is 40 at night and the car has never struggled like this to start. any suggestions?
Old Jan 24, 2024 | 06:40 PM
  #36
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
You will have to find out if you have a drain and/or if your charging system is working properly (alternator, voltage regulator, bcm, etc)
Old Oct 13, 2024 | 11:37 PM
  #37
ROMAN97's Avatar
Originally Posted by beejAMG
how the heck is this a battery issue?
this is s warning that your SBC is gonna go anytime soon.
next thing ill see, you'll start a thread saying your car is a piece of junk coz you lost your brakes "without" any warning, then youll say youll never buy another Mercedes Benz and how you pay for so much money and it almost killed you.
It could very well be battery alternator. Just had this happen to me. Alternator failed and car shut off and this was the message it was giving me.
Old Oct 14, 2024 | 11:42 AM
  #38
jimyj's Avatar
E320
It sounds like the intermittent "Reduced braking power" message and ABS warning on your E350 could be related to a few potential issues. One common culprit is the brake booster or the electronic brake control module, especially given the age and mileage of the vehicle. Problems with the brake booster, such as a vacuum leak, can reduce the boost assist to the brakes, leading to a loss of braking efficiency and triggering warning lights. Additionally, faulty wheel speed sensors or connections can intermittently disrupt the ABS system, leading to erratic behavior and warning messages. Electrical gremlins in older vehicles could also cause communication errors between the ABS sensors and the car's control units. To dig deeper into the issue, I recommend checking the fault codes from both the ABS Control Module and possibly the Brake Control Module. These modules will help isolate whether the issue stems from a sensor, a wiring problem, or something more severe like the pump or electronics in the brake system. Using a comprehensive scanner like the youcanic full system scanner will give you access to all these relevant diagnostics. Keep in mind that a basic code reader, such as the Bafx OBD2, might only show generic codes and miss detailed brake system faults. Have you checked if the brake fluid level is adequate and inspected the condition of your brake pads and rotors? Sometimes, these simpler checks can reveal underlying maintenance issues that contribute to warning messages.
