Go Back  MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W211)
2006 e350 4matic engine replacement >
E-Class (W211) 2003-2009
Old 01-26-2017, 11:49 PM
c320
what years motor is compatible with 2006 E350 4matic
i need a replacement motor for mine but not sure what years to look for
it seems like all the way up to 2010 is same motor but i just want to double check before buying one and find out it wouldnt work
must be 4 matic
does the 3.5L motor from the ML work in e350 also?
as far as i could find its an identical motor except instead of balance shaft issue it has cam gear issue which is much easier to fix than balance shaft replacement and m ok with that i can just take the cam gears from e350 and swap them into the ML 3.5L motor lol
raverx3m is offline
Old 01-27-2017, 06:46 PM
2009 E550 2000 Honda civic mash n' go
potomac german auto in maryland has 7 or 8 2009 E350 4matics engines for sale....
google potomac german and get it shipped. I'm sure there willl be a core charge. You wont have engine issues with it either. unless you neglect..... (used)
cmriv is offline
Old 01-27-2017, 09:34 PM
c320
nice thanks ill check them out.
im still looking for which years/models would fit in this car though
raverx3m is offline
Old 01-27-2017, 11:29 PM
2007 Gl450 2006 cls55
All m272 motors are interchangeable only differences are the oil pans and pick up tubes on the oil pump
bbspoolside is offline
Old 01-28-2017, 09:45 AM
2006 E350; 2008 911 C2; 2005 C55; 2003 360 Modena
Potomac is an LQK affiliate. Search the LQK site and you'll see nationwide availability.
kjb55 is offline
Old 01-28-2017, 07:42 PM
c320
so theres no difference at all in m272 motor from 2006 and 2010?
sensors intake manifold etc?
raverx3m is offline
Old 01-29-2017, 12:48 AM
There are differences. But a liquidatior will tell if so or not. Some m272 have vacuum pumps on rear of cylinder head. Not sure what the cutoff is tho
cmriv is offline
Quick Reply: 2006 e350 4matic engine replacement
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
