Odometer showing ------
hi, I have the dashes as well. Apparently caused by a dead battery (not sure if true). Any help is greatly appreciated!
I have 2015 Honda Accord Sport Sedan. My airbag light came on and my mechanic hooked up scanner via OBD connection. He attempted to adjust settings to turn off airbag light and was not successful, however afterwards the cluster information is all gone. The odometer shows dashes (- - - - - -) and the outside temperature is gone. I am not able to go through oil change life data. I went back to him and he can’t figure out which setting he deactivated. So I’m pretty much stuck with this now. (See photo)
My airbag light came on due to front impact sensor after fender bender and had my SRS module cleared by SafetyRestore However I am not able to find a fix for odometer. I am located in Queens, NYC and would appreciate any input. Thanks y’all!
They both use Bosch CANBus modules and gateways architecture licensed to respective OEM.
The big deal is the use of OBD DIAGNOSTIC PORT
> To help you out:
scan the car with a compatible scanner to retrieve faults. These clues
Don't waste time telling a shop how to work - Find a place you trust can do what's needed.
Paying once for a fix will save you money from
Look into Honda forums: tons of these honest workhorses on the road.
