E-Class (W211) 2003-2009
Sway bar link replacement
Old Mar 20, 2017 | 11:38 AM
plasma's Avatar
2003 E320
I had a noise coming from the drivers side when I drive slowly over bumps. The noise sounds like a crunch of metal. This past weekend I found out that the sway bar link where it's connects to the roll/sway bar. I've marked the picture with a red arrow.
Is it easy to change this? Are there any concerns with there being pressure applied to the sway bar when I remove the sway bar link? I really didn't find a good DIY but if you know of one, please reply with the link.
Thanks..
Old Mar 23, 2017 | 12:59 PM
plasma's Avatar
2003 E320
has anyone ever done this replacement?
Old Mar 23, 2017 | 06:27 PM
hangit06's Avatar
2006 E320 CDI
Doing the whole front end as I write. The sway bar link by itself should not be difficult.
Old Mar 23, 2017 | 06:34 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
simple diy job. jack vehicle up. r/r wheel. soak whatever you are using in pb blaster. loosen bolts and remove that little rod you see.
spring link bushings are split/cracked btw!
Old Apr 3, 2017 | 10:35 AM
plasma's Avatar
2003 E320
what are the spring link bushings?
and do I need to make sure the front is level so the sway bar doesn't have any tension?
Old Apr 3, 2017 | 06:48 PM
cmriv's Avatar
my advice would be jack stands. and use the floor jack to regulate pressure on sway bar itself when you are r/r. You can do one at a time but if the sway bar is unsprung i would theoretically think it would be more easy to replace the end links.
Spring link bushings are the bushings that are in your spring link arm. S/l arm is the arm that strut, end link, ball joint are attached too. The bushing is the rubber thing that rest's in subframe.
