E-Class (W211) 2003-2009
temperature 60 degrees celcius
Old Mar 22, 2017 | 09:15 AM
albania's Avatar
e220 cdi 2005
is it normal if the running temperature is 60 degrees celcius ??
in traffic it goes 80 degrees
thanks
Old Mar 22, 2017 | 11:29 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
No, verify it with other thermometer, but most likely you thermostat is stuck open.
My 2008 no longer has thermostat, but computer-operated electrovalve.
That adds to troubleshooting and cost as well.
Old Mar 23, 2017 | 01:53 AM
cetialpha5's Avatar
It's a common problem. I replaced mine with a Wahler thermostat which is OEM for MB. It's pretty much identical except for one spot that would have the MB logo and that's scratched out. I also replaced the pulley, belt and tensioner while I was it it because one of the pulleys has to come off anyway to replace the thermostat and those are also known to go. Gas mileage also improved slightly after I did it.
Old Mar 23, 2017 | 04:41 AM
albania's Avatar
e220 cdi 2005
here it shows only with removal of the thermostat, right ??
Old Mar 23, 2017 | 08:05 AM
mtrevelino's Avatar
2006 E320 CDI
Here are the instructions for the US e320 model.
Mike T.
File Type: pdf
Old Mar 27, 2017 | 02:22 PM
albania's Avatar
e220 cdi 2005
Just changed it but it seemed ok, it should be open if damaged??
It had 2 springs and 2 caps, both seemed opened.
The surface was clean and smooth everywhere
I am skeptic if it was damaged
Old Mar 29, 2017 | 03:47 AM
albania's Avatar
e220 cdi 2005
Cool
I have tried the car now on the highway
now it is 90 degrees all the time
thanks
