E-Class (W211) 2003-2009
Video of suspension knock/pop...
Old Mar 27, 2017 | 10:35 PM
ps2cho's Avatar
E
Finally got a good video that the suspension knock I am experiencing happens. Its not all the time, but with enough of the weight shifting, it does it.
It typically makes the noise when I am going at slower speeds <10mph. No odd sounds or noises at higher speeds, even if I go around a corner fast.
Have 122k now. 2008 E350 4Matic
I've replaced:
Lower control arms + ball joints
Upper control arms + ball joints
Sway Bar End links
Any ideas if that sounds like anything else?
Old Mar 28, 2017 | 12:32 AM
angelglo's Avatar
Veteran: Marine Corps
s500 GL450 GL63 Z71XL Yukon 67 396 SS velle 68 Vert Camaro 69 RSSS Vert Camaro 75 Blazer
Motor mounts?
Old Mar 28, 2017 | 02:46 PM
ps2cho's Avatar
E
Originally Posted by angelglo
Motor mounts?
did them 10k ago both sides
Old Mar 30, 2017 | 10:54 PM
F1Fan's Avatar
I would check the lower arm that attaches to the shock/strut. There is a rubber bushing that can deteriorate after a few years. Get under the car and try moving the arm and also rotating the arm. The rubber bushing will be torn if bad.
I would also check the condition of your struts. A worn strut can cause a type of klunk noise. Check for sign of fluid leak from the strut, or maybe it has dried on the outside of it.
Old Sep 2, 2017 | 01:53 AM
Dnasty's Avatar
2010 e550 coupe
Motor mounts?
Bad motor mounts can cause that sort of a noise?
Old Sep 2, 2017 | 12:00 PM
konigstiger's Avatar
'71 Pinto
Just a thought, since you exhausted all else check front axle support (torsion noise): http://workshop-manuals.com/mercedes...es/page_20234/ + next pages.
Old Sep 3, 2017 | 09:33 AM
Matthew Stewart's Avatar
2008 E320 bluetec
Believe it or not I had the same noise and it was the bottom bolts to my motor mounts had vibrated out due to me not torquing them down properly. . I would start by tightening every bolt to the suspension, sway bar strut, brake, sub frame, just to be sure.
Old Sep 3, 2017 | 02:36 PM
Dnasty's Avatar
2010 e550 coupe
How important is it to torque this stuff down under compression? Is that what you failed to do the first time which caused the issue? Some of this stuff is damn near impossible to get a torque wrench to while you have the tires on the car unless you have an actual lift.
Old Sep 8, 2017 | 01:38 PM
ACjr's Avatar
2008 E550 and 1984 Porsche 944
Suspension Clunk
Had the clunking noise. Just replaced front sway bar and links.
Old Sep 9, 2017 | 09:24 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Just DIY replaced the outer tie rod links on ours. Clunk/ rattle is gone.
