E-Class (W211) 2003-2009
Mis-fire frustration
Old Apr 18, 2017 | 12:46 AM
patabs's Avatar
03 E500
This is a new post to an old problem that has now chosen me. I don't know if anyone has figured this out, but while jumping into the throttle last week my 03 E500 fell flat at around 5000 rpm. I ran the code for the check engine light and it came out cylinder #3 mis-fire. I started the car a few minutes later and it reset for the most part. The check engine light even reset after three more normal starts. I ran it hard again a few days later and the same thing happened, only this time the code read cylinders 3 & 4 with the O2 sensors. I replaced the plugs, which the car needed anyway, and nothing changed. I replaced the plug wires and again, nothing. I want to try coil paks next, but this is getting pricey. Anyone able to shed some light on this? Thanks!
Old Apr 18, 2017 | 04:10 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
If you wish to try coil packs next, move the coil packs to the opposite bank first and see if the problem moves.
--Kyle
