E500 Wagon Airmatic Issues - Bear with me
Figured I would start with the compressor because that's what the 5503 code seems to be usually. Got a pump/relay from RMT yesterday and replaced it. When the car turns on and the compressor engages, you hear a rhythmic thump while the car is "inflating". You can see the wheel go up and stop every time the thump happens. It does this over and over for a few minutes then the compressor stops running and the wheel eventually settles back down low. There's no visible damage to the strut there.
After last night, now the passenger side front is down some too. Not as far, but noticeable.
A couple of things have me wondering:
1. when I put the air line back into the new compressor, the 10mm fitting around it just keeps turning. It never seems to stop. This isn't a new brass fitting, I re-used the fitting from the old compressor.
2. Could it be a bad valve block? The leak is obviously VERY fast, like it pumps up the wheel but once the compressor stops, it comes back down quickly.
For proper troubleshooting you need to monitor system pressure, but still spray bottle with soapy water can turn priceless.
The compression fitting turning around is not a good sign. Confirm it with spray of water.
You can follow my topic about compressor rebuild where I ended up adding a Tee on the system, what allow me to put pressure gauge and then shop compressor for testing.
But with such big leak it should be pretty easy to narrow it down.
But the compressor is protected from overheating by computer program that will time out and give it cooling period, so that is what you might observe.
Per my experience the time-out is 90 seconds and then about 5 minutes of cooling down. When 2 or 3 attempts will not keep the suspension up, you will get a warning.
Front only cost in $30's but take some labor.
FF to yesterday. Two replacement axles and two arnott struts that showed up yesterday. Working on the left side, finally got the axle in, then figured out how to get some air out of the strut by plugging it into the car and using my MB II (Arnott was definitely no help there.)
Got everything in, a bolt through the bottom of the strut into the control arm, both sides of axle in their respective places. Was putting bolts on the top of the strut when I noticed the Voss air line connection looked...interesting. It was at an angle and I thought "well maybe Arnott figured out that this configuration works a bit better than stock". Famous last words. Went to insert the air line and the fitting just came out of the strut. F#*K! Tried to reinsert it, thread it, nothing worked. Called Arnott right before they closed and they told me the whole strut had to be replaced. So I had to pull the strut BACK OUT, pack it up, get it to FedEx so they would ship me another one. Good lord.
He took the car apart and order left door. The only source -dealer took 3 weeks to deliver ... right door.
Shop space is not coming free, but he couldn't pass the 6 weeks of storage to customer who was paying for door replacement if you feel the trend.
Good for you you can park the car and take the other for commute.
