E-Class (W211) 2003-2009
jumpy jerky transmission
Old Apr 13, 2004 | 12:24 PM
michael10128's Avatar
2014 E350 4Matic/2011 E350 4matic / 2003 E500 /2000 CLK 430
is there a software update or SB for a transmission that is jolty at low RPMs, not always selecting the lowest possible gear at low rpms in traffic so i get a jolty hesitation as if its in to high of a gear and then a surge as the torque builds... i also notice a jolty springy surge when cold ...
its an 03' E500.
Old Apr 13, 2004 | 12:45 PM
moa4r's Avatar
S4
Re: jumpy jerky transmission
its an 03' E500.
i believe there is one, you may want to search this forum for more info (if you're dealer doesn't know)... does this happen all the time, or just on the rare occasion?
Old Apr 13, 2004 | 02:22 PM
alfcruiser's Avatar
MY12 W212 E350
I have the same exact problem!!
I just got my car back from the dealer, SRS failed, they replaced the audio gateway, and I asked them to check out this same problem.
They tell me it is normal, to me sounds like a bunch of crap, especially when the car registered in the system the times this occurred to me (apparently it keeps track the times the transmission does this).
I did a search on the forums and found the following bulletins:
ENGINE
Bulletin P-B-07.00/28 - ECM
Bulletin S-B-54.21/101 - ECM
Bulletin P-B-07.00/28e - ECM
I gave these to the dealer, and the service guy tells me that bulletins are tied into VINs and that mine did not need it. This again sounds like a bunch of crap to me.
Let me know what else you find out. I'm scheduled to go back to the dealer in 3 months for Service D, and I want to make sure I have all the info I can to support my case. I had the best Service Rep 2 years ago, no questions asked he would look into things for me, now I gotta justify, and practically prove my case to get any work done, and MB wonders why its survey feedbacks are negative.
-alf
Old Apr 13, 2004 | 02:30 PM
madde500's Avatar
I noticed it too, most of the time when I enter the on ramp to the highway. It's jerks into gear.
Old Apr 13, 2004 | 02:38 PM
moa4r's Avatar
S4
september 24st??!!
