Problems SBC pump unit.
Mercedes E 220 cdi automatic
Michael20953
Drives: Mercedes E 220 cdi automatic
Exclamation Problems SBC pump unit.
I all.
I have a 2005 Mercedes E220 CDI Automatic.
I Recently got this fault message.
Service Breaks.Visit Workshop.
My Mechanic got it checked for me and the conclusion was that the SBC unit was the problem.
I was have searched Google for advice and have came up with a lot of information on this fault.On Honest John I discovered the fault message I got is a common problem on the 2003 to 2006 models and there was some sort of recall on the SBC unit.
On an other site the problem SBC unit was replaced cost free but only after forcing the issue with the Mercedes garage.
In my case my Mercedes E 220 CDI has had a service every year.
An average of 4000mls per year and this adds up to 48000mls todate.
As you can imagine it is in perfect condition or was till this message appeared.
I quoted 2000euro to replace this unit but I believe that the SBC pump unit should be replaced by the Mercedes garage on the recall bases and will insist on it.
I also believe that Mercedes should have contacted me and anyone else who was likely to have this problem.
As this is a major safety issue l think they have let us all down and should be ashamed and if necessary shamed.
You may have guessed that I very annoyed with them and feel that they are to blame for the position I find myself in.
If anyone can supply me with solid information that I can use when dealing with The Mercedes company when insisting that they carry out the SBC pump replacement.
I all.
Michael20953 (05-02-2017)
Received 1,730 Likes
1922 Ford Model T / no OBD
You should read more carefully.
"Service" means ... service and is not a fault.
From your mileage sounds like you push brakes a lot and don't have mechanic who can read the pedal count.
SBC was recalled in USA, so check with your dealer what applies in your country.
Also earlier model had lower count, that was re-flashed by dealer for additional use.
So once again - call your friendly Service Adviser and have him check your VIN for updates.
Maybe you get lucky?
Pumps new sell in USA for $1070, while rebuild units $700.
