E-Class (W211) 2003-2009
Brake Part Issue????
Old May 31, 2017 | 10:20 AM
Me2's Avatar
Me2
2006 SLK55 AMG, 2005 E500, 2009 G55 AMG Kompressor
I have a 2005 E500. VIN WDBUF70J05A797111. I need Front Rotors and Pads Napa lists two parts, one w/sport package and one w/o. Neither fit my car. Went to Napa because the dealer is 50 miles away but now I am going to the MBD. The rear pads and rotors from Napa fit perfectly...
I am wondering, while waiting for the dealer to get back to me, if there is something special about this car? When I bought it, used, the MBD told me that this is a German Car. That the original owner actually went Germany to select it... ??? Thanks, Jack
Old May 31, 2017 | 11:32 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
https://www.fcpeuro.com/products/mer...pagid-w211fbk2
http://www.autohausaz.com/search/pro...0Brake%20Rotor
The only difference I see if between sport and non-sport models.
Old May 31, 2017 | 11:58 AM
konigstiger's Avatar
'71 Pinto
EPC OEM part #s:
Attached Thumbnails Brake Part Issue????-front.jpg   Brake Part Issue????-rear.jpg
File Type: pdf
Old May 31, 2017 | 03:16 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Every REPUTABLE seller will match the part to your VIN.
Old May 31, 2017 | 05:57 PM
Me2's Avatar
Me2
I'm back from my 100 drive to the MBD. Had to special order the rotors. Part Guy assured me that PN 211-421-09-12-64 is the correct part.
Nice day for a top down drive in my SLK-55 AMG.
Old Jun 1, 2017 | 02:07 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
Your parts guy is correct
--Kyle
Old Jun 5, 2017 | 05:35 PM
Me2's Avatar
Me2
Question????
Pads, rotors and sensors were replace. No issues. All went well. However the pad worn message is still on. I am assuming that one of the sensors is new defective or I broke one... Can someone confirm that I can check each sensor with a ohm meter for connectivity???
Old Jun 5, 2017 | 06:48 PM
Me2's Avatar
Me2
On second thought... I think I can take one of the old sensors. Cut the wires and connect them together. Unplug each senor one at a time. Plug in the dummy sensor and see if the message goes away.
Old Jun 5, 2017 | 06:59 PM
Me2's Avatar
Me2
But first... Pushed on the sensor plugs with a screwdriver. Think.. The RR clicked in.. Bottom line message is gone..
FYI, I waited for the computer to go to sleep. Then disconnected the battery and unplugged the SBC. After I was all done, re-plugged SBC then hooked the battery back up... Work great for me..
