E-Class (W211) 2003-2009
Need wiring diagram for head unit
Old Aug 22, 2017 | 07:25 AM
Ronald Anthony's Avatar
W211
Exclamation Need wiring diagram for head unit
Hi
I decided to buy aftermarket head unit and when sent the photos of my current head unit to the seller he was confused and asked for wiring diagram.
My car is 2004 V8 Japanese W211 Avantgarde
Old Aug 22, 2017 | 06:13 PM
W211
Thumbs up
Originally Posted by Plutoe
Post your VIN and when konigstar wakes up he will no doubt post and answer!
Thank you so much. Here is the VIN : WDB2110701A048262
Old Aug 22, 2017 | 06:43 PM
konigstiger's Avatar
'71 Pinto
Part # does not match EPC nonetheless, I suggest you contact either MB or Panasonic Automotive - Japan they “may” be able to assist with PIN assignments.
File Type: pdf
Old Aug 22, 2017 | 07:07 PM
W211
Thumbs up
Thank you. I will try that
Old Aug 23, 2017 | 12:46 PM
'71 Pinto
Plutoe may have answered his own wake-up call
Old Aug 23, 2017 | 03:40 PM
W211
Unhappy
I contacted MB and they sent the following image
which I think is not useful at all
I also sent the file provided by Plutoe to the seller he said nothing about it
Old Aug 23, 2017 | 05:33 PM
'71 Pinto
Check your private message.
Old Sep 21, 2017 | 08:21 AM
W211
Cool Update: I made some progress
I tried to disconnect some of the connectors and see what happens. I found that the important connectors are these 2 only.
Blue arrow points to power connector and Green arrow points to can bus and "other stuff" cable. If you only connect the power cable, command won't start and SRS malfunction message appears on dashboard display. After connecting the green cable again SRS message disappears and steering buttons works perfectly. the only thing left before replacing head unit would be resolving SRS malfunction mystery
