E-Class (W211) 2003-2009
SBC AND PART NUMBER and compatibility
Old May 10, 2024 | 09:34 AM
  #76
Dragiya's Avatar
S211 E240
SBC
Hi,
My VIN is WDB2112801X169053 for S211,E240. What is compatible SBC part #?
Thanks in advance.
Old Aug 20, 2024 | 12:53 PM
  #77
GenericPeanut's Avatar
W211 E320
Hi, is someone able to tell me which SBC's fit my car, please?
VIN: WDB2110262A380343
Faulty SBC P/N: SBC A 004 431 99 12 Q1
Many Thanks
Old Aug 23, 2024 | 03:35 AM
  #78
Adnan Hussain's Avatar
E500 Station wagon
SBC Replacement part
Hello,
Wondering if someone could also check my VIN for SBC part number. Thanks so much
WDB2112701A460888
E500 - 2005
Old Sep 6, 2024 | 08:06 AM
  #79
Ahafez5's Avatar
W211
W211 e240 SBC replacement number
Hi all ,
could you please help with the compatible sbc number for the VIN WDB2110615A642446.
the faulty sbc number is A 005 431 51 12.
Should o replace the esp control with the replacement unit?
thanks
Old Nov 5, 2024 | 07:35 PM
  #80
Ahafez5's Avatar
W211
Hi konigstiger
I have W211 e240 2005, My VIN number is WDB2110615A642446, i have an issue with esp,sbc compatibility
i have bought old sbc A005 431 8112 need to check if it compatible with my car or not , and what is the compatible ESP number with this sbc unit.
Also please , i have the below sbc units in my garage , i need to check the esp compatible with it.
-A005 431 7212
-A005 431 8112
-A005 431 5112
Thanks in advance for help
Old Nov 5, 2024 | 07:39 PM
  #81
Ahafez5's Avatar
W211
ESP compatible number
Hello everyone, i am seeking your help with the compatible ESP number with replacement for the following SBC units
-A0054318112
-A0054317212
My VIN number is WDB2110615A642446 e240 v6 2005
Thanks in advance
Old Mar 2, 2025 | 11:32 AM
  #82
Galvoz's Avatar
SBC Compatibility E270
hello everyone,
can someone tell me the compatibility of this sbc unit (mounted on a 2004 e270 avantgarde)?
unit label:
  • 0 265 960 013
  • ID0D21032216
  • HW 29/02
  • SW 06/03
(i want to change the unit because i have these DTCs:
  • Actual and Stored: C2131
  • "only" Stored: C25D4, C26BA, C26DE
if needed i can provide the VIN Number.
thanks
label on SBC hydraulic block
label on SBC motor
label on SBC motor
Old Mar 2, 2025 | 04:34 PM
  #83
Galvoz's Avatar
Originally Posted by Plutoe
need the VIN for my help
hi,
here's the VIN: WDB2110161A334652
thank you for the help
Old Mar 13, 2025 | 08:17 AM
  #84
Weevil's Avatar
2003 Mercedes Benz E320 Cdi Estate
SBC Pump Compatability
Hello!
My 2003 E320 Cdi SBC pump needs to be changed.
The Vin Number of the vehicle: WDB2112262A393148
Requesting some help to see if a replacement pump is compatible.
Current SBC part number: A 004 431 99 12 Q1
Possible replacement: A 009 431 26 12 Q3
Many thanks!
Old Mar 13, 2025 | 09:46 AM
  #85
Weevil's Avatar
yes the 009 431 26 12 is compatible.
Great, thanks for you help and speedy response! Smile Thumbs up
Old Mar 13, 2025 | 11:16 PM
  #86
Azeem's Avatar
W211 E270 cdi 2004
My VIN is WDB2110162A439268, could you please let me know the compatible part numbers for SBC unit.
Thanks in advance
Old Mar 14, 2025 | 08:13 PM
  #87
Azeem's Avatar
W211 E270 cdi 2004
Thank you
Old Mar 27, 2025 | 03:30 PM
  #88
Blackwhite's Avatar
W211 E500
SBC compatibility
Hi,
MY VIN number is: WDB2110702A274605
What SBC pump numbers will fit my car?
I got A0094312512Q3, BOSH part number: 0265960057 and I am not sure if this is the right one.
Old Mar 28, 2025 | 05:13 AM
  #89
Blackwhite's Avatar
W211 E500
SBC Compatibility
Hi,
The pump in the car is A0044316912Q2 / 0265960013.
I got a replacement A0094312512Q3 / 0265960057, and I am not sure if this is the right one.
Old Mar 28, 2025 | 10:42 PM
  #90
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Post a photo of the VIN under your windshield and we can help you.
Your profile shows a W212 diesel engine but you are asking about a W211 E500 petrol engine. Just give us the photo of the VIN. SBC was not included on any MB cars after the 2006 model year.
And what is with the "AMG" diesel?
Old Mar 29, 2025 | 08:49 AM
  #91
Blackwhite's Avatar
W211 E500
My profile was showing my previous car ( amended now). It was the AMG package xD
The VIN above is the correct one, and now I have a W211 E500 Saloon from 2003
VIN
VIN
Old Mar 29, 2025 | 12:16 PM
  #92
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Your VIN does not come up in the database of the parts catalog.
nemigaparts.com
The W211.070 does show up under the W211 section for an E500.
From there go to section 42 (Brakes).
https://nemigaparts.com/cat_spares/e...211070/64u/42/
Then to subsection 064 "Hydraulic Unit".
https://nemigaparts.com/cat_spares/e...70/64u/42/064/
Your car is "--> Code 806". Model years 2003 to 2006. "Code 807 -->" is model years 2007 and later.
Here is where it can get confusing...the part number on the SBC is separated differently than the parts catalog. i.e. My SBC (in a model 211.076) is stamped A 005 431 81 12; in the parts catalog it is A 00 543 181 12. It is listed as "Hydraulic Unit" while the previous version is listed as "Hydropneumatic Unit". What is strange is I cannot locate your posted part number in either the 211.070 section or the 211.076 section. My SBC part number I just posted, however, is listed in both the .070 and the .076 sections. Even the 211.072 Japanese market E500 version uses the A 005 part number I listed.
In this case, if the part number provided by you (A0044316912) is correct this sounds like a time to contact a dealer parts department. It is not in the online parts catalog linked above.
An online DuckDuckGo search brings up several leads. The first one is:
https://www.eps-elektronik.com/merce...6912-Q2_en.php
This link does bring up five associated part numbers.
They are located in Langelsheim, Germany which is a long way from where I used to live (Trippstadt) and even further from Texas.
Good luck to you.
Old Mar 29, 2025 | 12:41 PM
  #93
Blackwhite's Avatar
W211 E500
nemigaparts.com
Good luck to you.
Thank you.
Well, my car was ordered in Germany and imported to UK.It seems that the SBC pump I have as a replacement is a big unknown. Do you think it's worth trying to install it and see if it will work with my car, or should I not take the risk?
Old Mar 29, 2025 | 01:55 PM
  #94
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Originally Posted by Blackwhite
Thank you.
I don't feel confident on the "To install or not to install" question (apologies to Shakespeare). I would recommend contacting EPS Electronik and see if they would refurbish the one in your car
Old Mar 31, 2025 | 02:41 PM
  #95
Galvoz's Avatar
Hi,
i won't express if you have to try but i think it depends on errors too. If the old unit has good electronics and "new" unit has good hydraulics i'm pretty sure you can swap parts (at your own risk) and also on youtube there are videos about refurbishment (substitution of pressure accumulator and motor brushes). Remember that even if you have good sbc the installation and bubble removal process is important too for good operation (you need proper diagnosis equipment).
Hope that helps, best regards
Old Aug 10, 2025 | 04:39 AM
  #96
Saywot's Avatar
2004 E240
Australian E240 SBC
My VIN is WDB2110612A662580.
I'm hoping I can use an E320 SBC or anything really, 'cause there's nothing around for an E240
Old Aug 21, 2025 | 04:28 AM
  #97
mmpa's Avatar
E400 w211
SBC 0054310512 E400 2004
Can i fit this with 0054317112,old is 0054310512 and fault codes P2000 P2010 C1611
WDB2110281A536143
Old Jan 5, 2026 | 09:15 AM
  #98
real.off.road2@'s Avatar
SBC Issue
Hi, I'm looking to buy an used working SBC hydraulic unit. My vehicule VIN number is WDB2112261A268087
Can you please share me the compatible references of SBCs ?
Thanks in advance
Old Mar 17, 2026 | 08:52 PM
  #99
dome5505's Avatar
i have a 2003 e55 with sbc number A 004 431 69 12 Q3 and i came across a sbc that was being sold for 110 dollars and wanted to know if it was usable the sbc is part number A 009 431 27 12 Q1i was told that it could fit if not can someone let me know if it would as well as if not a part number that would fit vin is WDBUF76J33A327983
