E-Class (W211) 2003-2009
e350 thermostat P0128 code
Old Nov 14, 2017 | 02:30 PM
videoepete's Avatar
ML350, E350
I'm getting a P0128 thermostat code on my reader.
Seems to be like the thermostat is stuck in OPEN position - car is taking very long to warm up and produce heat inside the vehicle.
Does anyone know the MB part number for the thermostat?
I need to get a replacement and want to ensure I order the right one?
(2) Also, do I need to buy a sensor to with the thermostat or can i use existing sensor - I noticed some thermostats come with sensor some without ???
Thanks in advance for all your help!!!
Peter
Old Nov 14, 2017 | 03:41 PM
konigstiger's Avatar
'71 Pinto
VIN?
Old Nov 14, 2017 | 04:01 PM
videoepete's Avatar
ML350, E350
LAST SEVEN digits of VIN: B395490
Old Nov 14, 2017 | 04:20 PM
'71 Pinto
How about this, model year?
Old Nov 14, 2017 | 04:42 PM
'71 Pinto
I would have pulled VIN relevant part # from MB EPC, in the absence of full VIN and or model year use this site: https://www.mbdirectparts.com/
Old Nov 14, 2017 | 04:55 PM
videoepete's Avatar
ML350, E350
2009 E350 sedan 4matic
Based on your website thermostat is: 272-200-04-15
Old Nov 14, 2017 | 08:18 PM
cetialpha5's Avatar
I believe OEM is Wahler. Picked up this one Amazon not too long ago. Seem to work fine, Even had the spot where the MB logo would be scratched out. Otherwise looks identical. And it's $62 instead of $123 even though they misspelled Wahler. Spelled correctly, it's an extra $12.
Amazon Amazon
And if you're up there in mileage, I'd suggest getting the Continental kit for the tensioner and pulleys. You have to take off one of the pulleys anyway to change the thermostat. About $122 at rockauto.com after 5% off code found on retailmenot.com and after shipping charge. If you just bought those 4 items separately, it's probably over $150.
https://www.rockauto.com/en/moreinfo...443226&jsn=507
