2007 E350 4Matic Wagon: Sachs to Bilstein problem
There is a gap when I release the lower control arm (fully extending the shock). I just can't get it tight enough (top nut is maxed against the stem/rod sleeve as it should be). I don't have the top of the old shock to compare length of Sachs vs Bilstein. Here is what I have: https://www.fcpeuro.com/products/mer...n-bil-19235219
To me it just seems like I need a rubber washer. Nothing included in the Bilstein boxes. Perhaps I'm supposed to use the old ones (now missing). Suggestions?
Here are a couple photos to illustrate.
A 1/4 inch gap exists after inside washer/nut is tightened.
Close-up of the Bilstein 19235219 (OE equiv. to 2113264100 -- rear non-airmatic, just air springs)
Inside washer nut unique to wagon.
The Sacks/OEM version of shock (2113264100) with what appears to be an extra rubber stop/cover.
Closeup
The Bilstein 19235219. If the little sleeve were shortened (cut 1/4 inch) then I could tighten the shock flush to the car's body. But it would protrude into the rear cabin and likely interfere with the interior cladding. Sedans have more space here.
