what caused error code 930C??
I bought the Icarsoft 980 to scan and clear the codes on my 2007 350. According to the scanner, everything is in the good shape and clear except this one area. Under "system diagnosis" it showed error code 930C = Knowledge base configuration incomplete. The code is "current and store".... which meant it still happening. My question is:
1. What does this error code mean?
2. What cause this code? which component missing/fail/malfunction that cause this code? or how to confirm the malfunction part??
3. How to fix this issue? replace, recode...etc...
Note that the car is running perfect and smooth, everything is working as it should.... I just want to fix everything, make sure everything is in order
Any input will be appreciated.
'99 and '05 E55 AMG
I would say the unit is telling you it does not have the latest data in the memory for your 2007 W211. If you look at their website, it shows they support W211 model with V11.10 Diagnostic List through build date 05/2006. You can always contact their technical support and then post the answer direct from them.
@ nguyenphananh , just wondering if you figure out what that code mean? I have a 2008 E350 and engine light on, the MB II scanner shows 930C. I already updated the scanner to the most current version and no luck in finding out.
