E-Class (W211) 2003-2009
ignition harness connector to ignition coil replacement
Old 02-17-2018, 09:32 PM
Ngarcia1983's Avatar
07 E550
hi all, does anyone have the instructions to replace the connector to gnition coil as mine was brittle and broke when replacing spark plugs. i bought a new one unsure how to replace. Its Greatly appreciated.
Old 02-17-2018, 09:53 PM
07 E550
this is for my 07 E550. i looked at similar posts but none seem to help me out. my connector seems to have 4 pins.
Old 02-18-2018, 11:26 AM
kaane's Avatar
2004 Mercedes E500
It just like any connector for any application. Get a removal tool and get new connectors.
Here is the connector.
https://www.ecstuning.com/b-genuine-...ng/0225457026/
You can use this removal tool.
https://www.ecstuning.com/b-schwaben...ieces/ce-70-2/
Here is a decent video showing how to remove the pins from different type of connectors, not exactly the same, but they usually come out the same way.
Old 02-18-2018, 12:03 PM
konigstiger's Avatar
Received 4,411 Likes on 3,144 Posts
'71 Pinto
See attachment.
File Type: pdf
Old 02-18-2018, 09:12 PM
07 E550
thanks All,! i actually got them removed with a very small flat head screwdriver and breaking the old connector carefully to disengage the retaining pins on the actual connector. otherwise it wont budge by only using the very tiny screwdriver. hope this helps someonr else.
final question does anyone have the wiring diagram of the four wires with color description for each connector to coil. this will help anyone who forgets which wire goes on which pin in the connector.
Old 02-19-2018, 11:18 AM
'71 Pinto
See if attachment helps.
File Type: pdf
Old 12-23-2019, 10:26 AM
Ghettoeg6's Avatar
E350
Do you remember what exactly you did? i'm having the same problem right now.
Old 12-23-2019, 10:32 AM
07 E550
it was a bit hard. I had to use sharp cable cutters to destroy the connector as much as possible. I then inserted a very tiny flat head (type used on watches) on each pin and removed each one carefully. Just remember where each one goes. Took me about 30 mins to do this.
Quick Reply: ignition harness connector to ignition coil replacement
