E-Class (W211) 2003-2009
persistent P0019
Old Apr 9, 2023 | 02:32 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
You read post #12? https://mbworld.org/forums/e-class-w...ml#post8583049
In any case the following video is worth watching
Different engine, but same manufacturer.
Old Aug 6, 2023 | 11:19 PM
Al Golzari's Avatar
2010 C300
I have a 2010 C300 so yours should be the same. The camshaft oil control valves are located behind the camshaft magnets. You need to remove the camshaft magnet where you're getting the codes, and put a 24 mm socket and turn COUNTERclockwise but also have a second ratchet at the back of the camshaft as a counterhold. I did this last summer but if I remember correctly for the back of the camshaft it's a T60. Then you can undo the valves and clean and place back and see if that fixes it. I only had a P0019 but after cleaning it, the check engine light hasn't come back on in a year and power is restored. Good luck!
Old Jan 17, 2024 | 11:51 PM
marcanders's Avatar
2021 GLE AMG 63S, 2022 GLC, and 2013 ML350 4Matic
I am looking to do your fix this weekend. In one post you said reverse thread and then counterclockwise. Loosening it, do you remember which it was? Assume putting back in is the opposite. Assume you still haven't gotten a P0019 since?
