Aftermarket Audio upgrade?
2003 E500 (sport)
I'm interested in changing the stock audio system in my 03' e500. Bluetooth, XM etc. That said....I realize these lovely monsters (w211's) are balanced on an electronic needle. I don't want to interrupt ignition or braking
I also have an affinity for a "stock looking" dash. I don't want the car to look like a cheap disco...
Success stories and pics would be greatly appreciated.
Best,
DB
Best,
DB
There are multiple options for you. There is a Chinese head unit that operates on android auto and has a near-stock look. Just about any other third party head unit can be installed "plug and play" into the factory system with an Opti-1 module. There are several threads out there on third party installs. Here's the thread on what I did: https://mbworld.org/forums/audio-ele...ions-w211.html
I have a DNX9990HD head unit and a dash kit I don't need. If you're interested, shoot me a pm.
Here's a thread on the Chinese Android units: https://mbworld.org/forums/e-class-w...-pics-txt.html
Hi Everyone. I'd like to hijack this thread with a me-too scenario...
I'm also considering a radio upgrade and wonder if I could get some input.
I have a 2003 E320 with the Harman/Kardon Logic7 audio system and the crappy base-model small screen head unit. (NO-AUX, NO-BT, NO-NAV, etc.)
Not having any means of connecting my phone is a frustration. I currently use a Bluetooth cassette tape, but it needs to be removed and recharged somewhat frequently, which is annoying.
As I understand it, there are a few cons of going the aftermarket route:
I do not want to have to sacrifice audio quality and features for the sake of more features.
I also don't want to spend a fortune.
It seems that I can't have both.
So, I have 2 main questions:
- Spend a bunch of money on the radio...
- Then spend a bunch more on a steering wheel interface.
- Then it won't be able to drive all the speakers unless I spend even more money on a Fiber interface or extra amplifiers.
- If I do a fiber Interface, I lose surround and ability to fade - essentially downgrading to regular stereo - but all speakers work.
- If I opt for fiber bypass with sufficient additional amplifier(s) to retain all speakers, the cost and install complexity goes up - possibly to an unjustifiable level.
- Is there any new technology that improves integration of aftermarket radios, or have I hit the nail on the head regarding the issues encountered?
- Is there any other way to get an AUX input?
- Can the head unit be replaced an upgraded factory head unit? Would this add AUX input or is it wired in elsewhere?
- Are there any other parts that can be switched out to achieve this (or other improvements) without rewiring everything?
I'm in the same situation and I'm looking at this unit. Along with replacing the blown center dash speaker. I have the harmon kardon system with nav.
https://www.crutchfield.com/p_500ILX...tp=72310&avf=Y
The following 2 users liked this post by ps2cho:
Onyxthecat (07-08-2018),
StradaRedlands (07-11-2018)
