Fuel system, electrical
I have an 03 E500. Yesterday I stopped at a 7-11, when I came out the car started, sputtered then died. Had it towed home and started diagnosing things. I couldn't here fuel pump so checked fuse, it was good. Then checked to see if pump had power. It did not. Then checked to see if fuel pump relay had power (from continuous power side) and it did. So I hooked up a jumper wire to bypass relay and nothing happened. Still no power at fuel pump.
Now I'm really stumped. I've been looking all over but can't find a wiring diagram. Is there anything between the relay and fuel pump wiring plug?
Thanks for the help!
Adam
The link to the following post is for an E55 (*not* your E500! very different!) but will provide you some additional info that may or may not help.
https://mbworld.org/forums/showpost....5&postcount=36
Pelican Parts has a good troubleshooting guide:
https://www.pelicanparts.com/techart...mp_Testing.htm
There might be lot of reason why there is no power to fuel pump. Common is bad CPS.
Without a scanner you are walking blindfolded.
