E-Class (W211) 2003-2009
what are you running your tire pressure at on stock 17" factory wheels??? F&R
Old Jun 8, 2004 | 02:02 PM
michael10128's Avatar
2014 E350 4Matic/2011 E350 4matic / 2003 E500 /2000 CLK 430
what are e500 owners setting their tire pressure at..
the reccomended is 32-34 Rear and 26-29 front...any advice? i think its kinda low....
please only respond if you are running stock wheels..17" either sport or non sport since they are the same size
Old Jun 8, 2004 | 02:04 PM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
Re: what are you running your tire pressure at on stock 17" factory wheels??? F&R
I have 35 on both front and rear. Mine is a E320 w/ sport wheels (17").
Ride quality is fine, and handling is good.
Old Jun 8, 2004 | 04:18 PM
rarenaro's Avatar
Mercedes E500
michael10128:
32 across the board - front and back.
Old Jun 8, 2004 | 05:15 PM
BWL's Avatar
BWL
I own the E320 with sports package (17" wheels) and run 30 psi in the front and 33 psi in the rear. I may experiment running with a little more pressure. As far as I am concerned I do not notice any real difference in ride comfort.
Old Jun 8, 2004 | 05:23 PM
jabo's Avatar
E500W '03, Porsche Cayman S '06
42 PSI front and back on 17x8.5J stock 5split spoke
Old Jun 8, 2004 | 06:03 PM
bmms8's Avatar
MB
i just go by factory, plus 1-2 more lbs. i dont think it is a range of 26-29. one # is for a colder, or hotter tire i believe, it changes since the tire does expand while getting hot. GL
Old Jun 8, 2004 | 06:19 PM
Double Eagle's Avatar
2003 E-500
I run 32 rear and 27 front. I tried running higher in the front (32) and found both of my E-500's had a tendancy to wander. Lowering the pressure to 27 fixed the problem. At time of delivery of my Nav replacement E-500, I brought a tire pressure gauge with me and found there was 33psi in all the tires. After about three miles of driving, I reset the pressures to 27/32 and steering improved with no problems since.
Old Jun 8, 2004 | 10:52 PM
Randy B's Avatar
**SOLD***2003 E500
I go with the higher end of the 100MPH driving rec. pressures in the fuel door, for front and rear. Have noticed full even wear on the tires and no problems.
