E-Class (W211) 2003-2009
E500 Air Ride Problem
Old Oct 6, 2018 | 09:57 AM
Deeee's Avatar
2005 e500
Hi all, im new to this forum. I recently had my front driver side air strut & compressor replaced. Ever since then my car has been stuck high off the ground & i cant get it to return to regular ride height. Has anyone else had this problem?
Old Oct 6, 2018 | 10:02 AM
Deeee's Avatar
2005 e500
Found out its the rear sping out now smh never noticed
Old Oct 6, 2018 | 10:06 AM
C63AMGG's Avatar
C63AMG
Hi have you checked the leval sensors on the upper arms on front
Old Oct 6, 2018 | 10:27 AM
Deeee's Avatar
2005 e500
I have no clue where they’re located at. I’ve looked for the location on google but i can find the rear ones. I did believe that might be the problem but I didnt want to waste money on the wrong issue. Lol i just bought 2 new compressors when my original one was working fine.
*Update: I just unplugged the driver side sensor & the warning went away im going to go grab 1 from the junkyard today & see if that will bring it back down.
Old Oct 6, 2018 | 02:39 PM
Deeee's Avatar
2005 e500
After replacing the driver side height sensor there is no change... the car is still high & has the same warning message. Idk what to do next
Old Oct 6, 2018 | 06:46 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Have you had the car scanned with Star? You can't always check codes for this kind of stuff with an OBDII scanner, which is what most indy shops have. If it's throwing a warning message they should be able to see what the issue is. Without doing that it's a guessing game and you'll just be throwing money at parts.
Put your location in your profile too.
