E-Class (W211) 2003-2009
w211 led emblem
Old Dec 27, 2018 | 11:10 PM
haslami9's Avatar
2008 e350
w211 led emblem
Hi Guys,
I had a hard time locating a w211 thread for DIY Mercedes LED emblem install so i went ahead and made this.
I didnt take any pictures of my steps involved but feel free to ask me anything and i will do my best to explain what i did.
Old Jan 2, 2019 | 07:39 AM
gafitanu's Avatar
1967 250SE, 2022 GLC300 2023 EQB300, 2018 AMG GT
It looks great. What LED's did you use? You mounted them behind the star?
Thanks.
Old Jan 7, 2019 | 03:49 AM
Inspiredbenz's Avatar
SOLD W203..CURRENTLY DRIVING W211
Im interested in this ???
Old Jan 8, 2019 | 05:18 PM
haslami9's Avatar
2008 e350
Thanks! BTW, @Inspiredbenz I work in corona and live in Irvine. If you need help let me know, more than happy to help.
So there is a long process to this but i will explain.
Here is the grill i purchased for my 2008 e350:
https://www.ebay.com/itm/Black-W211-Grille-E-Class-07-09-GRG-W211-0708G-CL4-BK-Fits-Mercedes/263743859994?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m2749.l2649
Here is the link for the LED Mercedes light enblem i used:
https://www.ebay.com/itm/Illuminated-LED-Light-Front-Grille-Star-Emblem-Badge-for-Mercedes-Benz-06-13-Car/253900993915?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m2749.l2649
Step 1: What i did was remove the center star unit on the original grill that i purchased. If you look from the inside of the grill, there are three points that you have to pry out using a flat head screw driver. The emblem will then pop right out, leaving a hole in the center of the grille where we then will need to adhere the LED Emblem to.
Points to pry out the Emblem unit from Grille
Step 2: Next will be to removed the silver Mercedes emblem from the LED Mercedes Emblem unit. You can use your fingers to pry off this emblem from the unit (see image for contact points to pry off)
Points to remove the LED Emblem on unit.. Same points will then need to be cut flush for step 3.
Step 3: Now cut those silver contacts that are used to hold the top silver benz emblem flush(sand if you need to).
Step 4: I used JB weld Plastic clear weld glue to adhere the now flush benz emblem directly back on top of the LED emblem unit. Make sure not to use too much glue that it gets everywhere, especially where the Light from the LED will be emitted from (clear plastic on emblem)
Step 5: Next, your going to want to sand the back lip of the emblem (see third image) throughout the entire unit.This will help create a better bond once we glue it back onto grill.
points to sand flush, there are more sides on top that i didnt circle but you can find them once you have the unit.
Step 6: Cut out the area indicated for your front hood latch to go through. I cut some of the side as well so that it completely fit through. I will update with an image later on.
Cut out indicated area for front hood latch.
Step 7: Glu the LED emblem unit onto the Grill you removed the original emblem from using same epoxy from JB Weld. Make sure to keep an eye on the unit that it doesnt move from the center of the grill. I checked on it every 5 minuted for about 30 minutes to make sure it was set in the correct place. Also, dont use to much glue.
Step 8: I have LED front headlights from ddm tuning which require Code cancelers. I used the wire from the emblem to tap directly into my Code cancelers on my front left headlight. I know others who tapped into their city lights with cable splices so that the emblem only comes on at night but that process was to hard for me. Plus you cant really even see the emblem during the day so i chose to tap this way.
Hope this helps, let me know if you have any other questions.
Old Jan 9, 2019 | 02:28 AM
^ Thank You for the write up will def try this as soon as i can . I love the way it looks on your car man hopefully i get time soon
Old Jan 9, 2019 | 02:31 AM
https://www.ebay.com/itm/Black-W211-...53.m2749.l2649
https://www.ebay.com/itm/Illuminated...53.m2749.l2649
Actually this deserves a sticky lol you did a really good job explaining . Thank You once again
Old Jun 17, 2021 | 01:30 AM
eaglehawaii's Avatar
08 E350 AMG; 18 GLE 350
Just came across this thread ... Wow. Great job haslami9.
I wish there is a kit that one could buy to make this easier.
Old Jun 18, 2021 | 09:45 PM
User 7121's Avatar
I did mine a while back I actually got my emblem new at store for $15
Old Jun 18, 2021 | 10:40 PM
Beautiful!
I'd like to keep the chrome grill look vs. the black grill.
Would you mind sharing where you got your grill and the star? I am hoping they carry the chrome grill.
Mahalo
Old Jun 18, 2021 | 10:44 PM
tjts1's Avatar
C320
That's the tackiest shlt I've ever seen. I'm embarrassed for your family and friends.
Old Jun 19, 2021 | 04:41 AM
BenzNinja's Avatar
Former Vendor
really cool
Old Jun 21, 2021 | 03:19 PM
User 7121's Avatar
TJ ****
TJ **** I jus sent that message to you threw the personal message **** or what ever *****
Old Jun 22, 2021 | 10:42 PM
User 7121's Avatar
TJ T*ts
My other replies were deleted. You know only a str8 assh*le would respond like that. And a internet coward at that. I wish u said that sh*t 2 me n person I would school u on just how much of a B*TCH u r. A rude punk a*s b*tch. Not sure why my responses r deleted and yours stays. U know theres lots of sh*t on here that I see that I dont personally care for but I never think any one who is liking topic and participating on topic needs to be insulted because there tastes r different then mine. U must really think alot of yourself like your opinion is the only one that matters. Maybe its because people on here just ignore your ignorant a*s. I did till I couldnt anymore. I have no clue where u r but I frequent between Bakersfield and San Diego so So. Cal. If u have any issues with what Im saying here we can have lunch and discuss this matter if u r anywhere close and down. If u look at my name on here its E320G thats not a model Mercedes makes thats E320 Gangsta Mercedes may b your realm what u r familiar with but confrontation and violence is my realm or what im familiar with. Just thought u might want 2 know this before accompanying me for lunch.
Old Jun 23, 2021 | 08:54 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Simmer down... ladies
Old Jun 24, 2021 | 09:30 PM
User 7121's Avatar
That sh*t there is such a BIG PART of many problems today. People have no idea WTF is goin on but yet they wanna add there 2 cents in and think its funny or cute. In reality in person u would get broke off the same as that RUDE ****O
LE im still waitin 4. Normally u cant shut his as* up.
Where r u TJ T*ts?
Old Jun 24, 2021 | 11:19 PM
Always the ****ing the new guys...
Old Jun 25, 2021 | 06:31 AM
tjts1's Avatar
C320
Tell your mom to top up the cell phone she bought me so I can Facetime her late night.
Old Jan 26, 2024 | 04:33 PM
Luke81Roberts's Avatar
2004 E320 4matic
This looks pretty cool. Might end up blacking out all the chrome on my white e class after seeing this. I already have blacked out mirror turn signals. I'm afraid it will look dumb without black wheels though.
Someone backed into my grille (and didn't leave a note) so I guess its time for me to order one with an emblem and do the LED upgrade.
What store did you go to in order to get the emblem? I am trying to source one right now.
