Weird difference in air pressure between 2006 and 2007 cars? - MBWorld.org Forums
Go Back  MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W211)
Weird difference in air pressure between 2006 and 2007 cars? >
E-Class (W211) 2003-2009
Old 02-04-2019, 11:00 AM
w211
I have a 2006 E350 with sport package and just acquired a 2007 E350 with sport package and just noticed that the tire air pressure numbers are substantially different even though they're essentially the same car (3.5l, 7sp, 18"):
2006: 32 (35) front; 38 (42) rear
2007: 28 (29) front; 33 (35) rear
That's a 4psi difference in the front and a 5psi difference in the rear.
Any thoughts on why?
I'm running identical Michelin Pilot Sport AS 3+ on both and was wondering if I should err up or down or go exactly with the factory numbers?
irondad is offline
Old 02-04-2019, 11:46 AM
ygmn's Avatar
2015 E400
Notice the sticker is for staggered tire size... are your tires from older car the same size front and rear?
ygmn is offline
Old 02-04-2019, 11:52 AM
w211
They're both sport packages with 245/40/18 front and 265/35/18 rear.
The upper picture is the 2006 car fuel filler door placard, and the lower picture is the 2007 car fuel filler door placard with the substantially lower pressures.
I recall the 2007 models had something like 2,000 new parts, but that's a pretty dramatic drop in tire pressure.
irondad is offline
Old 02-04-2019, 01:11 PM
ygmn's Avatar
2015 E400
lower sticker does not list tire size.... so who knows.....as it is supposed to...
air pressure is calculated by axle load at the tire with normal driver and half tank of fuel.
tire on sidwall has load rating based on max pressure.
so you take actual load divide by tire load rating and mulitply by tire pressure at this max load. and round up up.
So maybe the staggered tires require bit more air then smaller ones for rear axle loads.
hence why you see an increase for more car loads.
also you see different for speed runs due to heat input to tires increase pressure which they are accounting for.
ygmn is offline
Old 02-04-2019, 01:33 PM
E250 BTC/ E320 BTC SL500
There might be cars weight difference, but tire pressure is a choice between comfort, tire wear and resistance (fuel consumption).
In times when mpg is top priority- manufacturers advise higher tire pressure.
I have a friend who drives his light Honda with 40 psi.
The 4-cylinder old car averages 35 mpg.
kajtek1 is online now
Old 02-04-2019, 05:27 PM
w211
Same car, same size wheels, same size tires, same rated tires, same weight (based on my research)... yet 4-5psi difference between 2006 and 2007.
irondad is offline
Old 02-04-2019, 10:43 PM
Agent-A01's Avatar
Phat
Look at your first picture.
The answer is there
That car came optioned from the factory with high load MO tires
Agent-A01 is online now
Old 02-08-2019, 10:29 PM
w211
2007 came with XL (extra load) tires as well.
irondad is offline
Old 02-11-2019, 12:05 AM
ptkacik's Avatar
2005 E320 CDI
My guess is that with the super low profile tires (which are almost always EXTRA LOAD), MB went with the high pressures in 2006 as did most manufacturers. I'm guessing that they saw higher center wear and did a rethink on how high they should be.
Backing off off on pressures would have improved tire wear and improved ride comfort. But I'll bet there was much discussion about this before it was changed this way.
Do you get high center wear on your tires? I'd bet you do at the rear but that's thrust related.
Just my two cents,
Peter
ptkacik is offline
Quick Reply: Weird difference in air pressure between 2006 and 2007 cars?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
