Intermittent P2602 Transmission Error
Vehicle is a 2005 E350 4Matic Wagon with ~175K miles. Had some weird issues - possibly went into limp mode briefly - self-corrected and got home. Pulled a P2602 code, "Supply voltage to solenoid valve is faulty".
I'm reading about earlier cars having an issue with oil getting wicked up to the TCM via the harness. Has that been an issue with the W211's also? If so, seems that determining whether the TCM, Conductor plate, or solenoid(s) have failed can be a challenge.
Thoughts?
Thoughts?
Go the easy way and check the battery first
I've seen the adapter plug w/ the two O-rings, p/n A2035400253. But it's been suggested to me that's only a fix for external leaks, not the issue of the fluid wicking up to the TCM via the harness. Yes, no, maybe???
It's a 10-minute-fix, not necessary to drain the oil/ remove the pan for this.
Okay, sounds like it's a good thing to do along with taking a look at the TCM to see if any oil has climbed up there.
