Code 6210 need help (Uploaded Video)
So right after installing new rear tires i go to drive off the lot and esp/abs malfunction. Basically traction light turns on flashes a few times and then you get esp/abs in the center. He is saying its sbc unit, im thinking its a speed sensor. Other then the steering getting stiff the car drives perfect. Not sure if the sound is normal or not.
Start the engine and turn the steering wheel full left, full right, full left, full right, center.
Originally Posted by tjts1
(Post 7743165)
I did that and nothing happened. |
Originally Posted by karpetcm
(Post 7743062)
https://cimg9.ibsrv.net/gimg/www.mbw...4cb22dcb24.jpg |
Without the appropriate scanner tool both you and your mechanic are just guessing.
Gotta just take it in and get it properly scanned at the dealer.
(Post 7743062)
https://youtu.be/_MeVD0GpIJ4 |
