How wide can i go on a W211 E350 4matic?
kinda depends on the offset. you can figure that out here. compare with your stock/current wheels/tires to get an idea
https://www.discounttire.com/learn/tire-size-calculator
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
W211 E350 4matic
Received 1,730 Likes
1922 Ford Model T / no OBD
I think 55 offset on 10" rims will fit rear, but front might hit suspension.
Than W211 come with different suspensions.
Bottom line, there is only 1 way to check for sure.
Even when the rim fits, when you install wide tire, the tire might rub.
