E-Class (W211) 2003-2009
2003 MB E320 CDI diesel overheats
Old Jun 6, 2019 | 03:18 PM
ventexan's Avatar
2003 E320, 1985 190e 2.3, 2007 E320
I am at my wits end! I cannot find the reason my E320 CDI overheats... bought brand new OEM radiator fan, scanned and no error reports, water pump seems ok, no water leaks, no broken hoses, etc.
Old Jun 7, 2019 | 02:16 AM
tjts1's Avatar
C320
Does the fan run when it overheats?
Old Jun 7, 2019 | 08:36 AM
ventexan's Avatar
Hi buddy. Yes, the fan works great. I am going to disassemble the entire water system, flush the radiator, check the thermostat and replace with coolant rather than water. I am in a Venezuelan coastal town and rarely does the temp fall below 80 degrees... *the car overheats almost instantly the moment I turn on the AC while driving. Parked, the car idles at normal temp even with the AC on...
Old Jun 7, 2019 | 09:37 AM
ventexan's Avatar
I am going to flush the system today and use coolant instead of water as median temp here in Venezuela is 80 degrees... Thanks!
Old Jun 7, 2019 | 09:44 AM
tjts1's Avatar
C320
I would take another look at the water pump. I suspect the water pump impeller is broken or fallen off the shaft.
Old Jun 7, 2019 | 10:26 AM
ventexan's Avatar
I will try that as well... it hurts to see the car parked there instead of cruising about town!
Old Jun 7, 2019 | 10:44 AM
tjts1's Avatar
C320
Another possibility is that you have a blocked coolant hose. Sometimes when the hoses get old inner layer will delaminate and fold over blocking coolant flow. It's impossible to tell from the outside.
Old Jun 7, 2019 | 10:47 AM
ventexan's Avatar
Excellent my friend. I will disassemble the entire system and check hose by hose, component by component. Thank you very much!
Old Jun 10, 2019 | 07:49 PM
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
Defect thermostat sensor. It's in the thermostat. Measure the temp. Bij hand. And verify.
