E-Class (W211) 2003-2009
TPMS stem replacements
Old Jan 11, 2020 | 10:37 AM
relinuca's Avatar
2009 E350 4Matic Sport sedan
I recently replaced all four tires and also replaced all four TPMS stems. MY M-B service manager says the stems should be replaced each
40K miles...sounds too frequent to me.
My replacements would probably fall in the "preventive mntce." category as I was having no TPMS problems.
Do these stems ever actually fail? Just wondering.
relinuca
Old Jan 11, 2020 | 12:47 PM
konigstiger's Avatar
'71 Pinto
If you are referring to valve (515 in diagram) never heard that before. Sensor (510) however, incorporates a non-replaceable internal battery of which MB recommends replacement every seven years regardless of mileage to answer your proactive maintenance question.
Old Jan 11, 2020 | 12:48 PM
CastorTroy's Avatar
2014 E550
yes they do. 40k is a bit early to start replacing them, but i've seen them go out at 60-90k. my mom's car just had them done, 3 were dead at 112k
Old Jan 11, 2020 | 07:10 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I sold my 2007 E320 BT last year and still on factory TPMS at 190k miles.
I am in contact with buyer and he did not replaced them yet.
But for the year the sensor would display warning only, with no psi reading on cluster, although my scanner would read not only pressure, but temperature as well.
