E-Class (W211) 2003-2009
W211 04 e320 misfire
Old Jan 26, 2020 | 11:35 PM
Majmv's Avatar
02 cl55 amg 08 ml350
Hello everyone. Loooooooooooong time lurker and new member. Own a 02 cl55 amg with 190k miles and a 08 ml350 with 170k miles. I turn my own wrench and have access to a lift and garage tools which is one of the reasons I can buy German cars. Unfortunately I have come across a hurdle when trying to fix my cousins 04 e320 wagon with 220k miles. He keeps getting p0300 with cylinder 2 and 5. So far me and cousin have changed the spark plugs, ignition coils, new maf sensor. Visually checked for any vacuum leaks but nothing. It runs fine in the beginning but when u rev it over 2000-3000 rpm it misfires like crazy. We r gonna check the fuel pressure next and check if the ecm is bad by checking the fuel injector connection using noid light. Any common failure of parts that I should check??
Old Jan 27, 2020 | 06:50 AM
speedlimit's Avatar
Administrator Emeritus
Welcome to MBworld!
Thank you for the photo and the intro. Moving your post to the W211 forum for help from fellow owners.
Bob
Old Feb 8, 2020 | 08:30 PM
Majmv's Avatar
Removed the cat and the misfire while accelerating hard is still there. Changed the fuel filter but still no change. When revving over 3k rpm it would start misfiring like crazy even after i let off the gas. But when I shut it off and remove the key and then start it back again no misfire and it won’t misfire if I keep the rev counter under 3k-2.5k rpm. Help
Old Feb 8, 2020 | 09:46 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Show off! Lol 👍
