E-Class (W211) 2003-2009
hit a pothot now i'm feeling a vibration
Old Jul 28, 2004 | 10:57 PM
TectiteE's Avatar
MGT, 12 CLS63 Launch
i hit a pothole today and now i'm feeling a vibrations at any speed above 20mph. i checked the tire and the rim inside and out, and there seems to be no bend. could the balance or something be out of whack from hitting the pothole?? or is the rim prob bent and i can't see it
Old Jul 28, 2004 | 11:13 PM
khaug's Avatar
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
My guess is that you've bent a wheel. You need to remove the wheel to properly check it, and may need a dial indicator to determine if, in fact, the wheel is out of round.
If the wheel is out of spec, I'd replace it. IMHO, trying to repair a bent alloy wheel is a poor choice, as it can never be made as strong as new again.
It's also possible that you damaged only the tire - broke the belt, or some such. A competent tire shop will dismount the tire and check both the wheel and the tire.
Good luck.
Old Jul 29, 2004 | 08:24 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
most likely chucked a wheel weight into that pothole :p
try and get them balanced first and see what happens.
Old Jul 29, 2004 | 11:42 AM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Exclamation Proper Evaluation of Your Problem?
There's one way to be sure what kind of a problem you have.
Find a shop that has a Hunter GSP 9700 machine, and the operator will be able to tell you exactly what your problem is, whether it be a bent, out-of-round or untrue rim, or tire damage such as inner belt problems within the tire, whatever.
No guess work here. It's worth going to the Hunter Engineering site to read all about this system.
See: http://128.242.141.111/pub/features/intro.cfm
This site has a locator feature also. Simply enter your Zip code and the distance you are willing to travel, and you're there.
HTHs
Old Jul 29, 2004 | 03:07 PM
alewifebp's Avatar
2014 BMW 550i
Last I checked the Locator on the site was way out of date. But, I agree 100%, don't get your car balanced unless they have the GSP 9700, especially when you have higher performance machinery and tires.
Old Jul 29, 2004 | 04:09 PM
Question Location in Jersey?
I don't know where in New Jersey he is, but . . . ?
It doesn't really matter because wherever he needs to go, it'll be well worth it. I've seen some pretty difficult problems cleared up so easily by that machine. I've been to their training centers in MO as well as the local one here in the L A area in Sante Fe Springs. Worth the trouble to go to if anyone has the chance.
Punched up 08601, and within 50 miles, Hunter lists 199 sights that have the GSP 9700.
HTHs
