Oil Consumption concerns
Is this oil consumption typical? What's causing the sudden brown and reddish residue? (I intend to get the used oil analysed.)
How "tolerant" are the 350 engines about low oil levels? With an 8.5 qt. oil capacity, I would think (hope) that a temporary drop of 2 qts. wouldn't be too dangerous..)
Thanks in advance for all responses. We love our E 350 and intend to keep it for awhile.
relinuca
there shouldn’t be any residue either so that’s very concerning. check for oil in coolant reservoir.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
something is off. these cars do not use 10w30 otherwise I would be cheapin out and running $1.50 a quart farm and fleet oil.
relinuca
Here is the list of MB approved and tested oil pertaining to 229.51 specs.
https://bevo.mercedes-benz.com/bevol...229.51_en.html
NOTE: 229.51 oil specs is actually for diesel engines. Not sure that is actually the case.
2q oil drop should trigger the "check level" message. If it is a short term situation it should not be dangerous.
I would personally send the oil sample for analysis and go from there. About Mobil-1 oil 0W-40: the oil consumption will not get any better with this oil grade. Try 5W-40. Given your ODO reading you could even try 10W-40.
IMO oil brand is a matter of personal preference, you can use any approved oil (try the link above).
relinuca
The OP obviously had no issues up to now so something beside oil viscosity is wrong.
That being said, ensure your crankcase ventilator valve or pcv is operating correctly and then try a heavier oil at the top of the scale to diagnose for bearing wear.
If the consumption goes down with thicker oil your bearings or seals are failing.
Valves or piston rings will lead to smoke out of the exhaust.
Compression test may be in order.
Best of luck.
