E-Class (W211) 2003-2009
09 e350 ABS ESP inoperative see operators man: How to reset or read code?
Old Mar 2, 2020 | 09:43 AM
e350forme's Avatar
fleet
I was driving about 10 mph and the drivers front wheel ABS kicked in, it pulsed a couple of times. right after, I got the error listed above. power steering seems to be much harder.
I have checked with OBD but no codes come up. I have tried to reset the trunk battery. I tried to remove auxilary battery but it does not appear my car has one. I cleaned the wheel sensor , it was quite dirty.
review of old threads mentions replacing abs sensor on that wheel.
Does anyone know any clues about this?
Old Mar 4, 2020 | 08:13 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
There'll be codes but you'll need a better scanner than a cheap one to read them. That's where to start though.
Old Mar 25, 2020 | 12:03 PM
e350forme's Avatar
fleet
so with a nicer tool I found the wheel sensor value is implausable. i cleaned sensor but was told the other end was in the axle. I heard that corrosion causes problems. Any tips? New axle?
Old Mar 25, 2020 | 11:49 PM
cetialpha5's Avatar
Search the old threads. It either the sensor or the seal. Only use MB parts, aftermarket doesn't seem to work right. I don't think you need to replace the axle, it's the seal.
Old Mar 26, 2020 | 10:50 AM
e350forme's Avatar
fleet
thanks , your right, up until now I thought it was just a standard ABS ring but that is not the case. dove in...
stealer has the "smooth ring" (not toothed ring) for 32 bucks. will post part number when available
Old Mar 26, 2020 | 11:23 AM
cetialpha5's Avatar
I believe they say it's a magnetic ring. If you give the dealer your vin, you should get the right part.
