E-Class (W211) 2003-2009
Airmatic stuck on high! Is this wire the culprit?
Old May 6, 2020 | 07:44 PM
suming's Avatar
2003 W211 E500
One exposed wire
Another slightly damaged wire
Last night the car was making an electronic buzzing sound on and off from the front right strut solenoid, when the connector was disconnected it would stop. I then noticed the suspension lifted to Max height and stayed like that. I have taken a look at the wiring by the compressor and found two exposed wires. Are they the culprit? No warning lights on dash. Appreciate any help. Thanks guys
Old May 9, 2020 | 09:32 AM
Onyxthecat's Avatar
06 E500 4Matic Wagon
I think the computer needs to reset the suspension. No codes for faulty circuits?
Old May 9, 2020 | 09:36 AM
suming's Avatar
2003 W211 E500
Doesn't seem to be showing any codes. Does a reset require Star. Appreciate your help bud
Old May 9, 2020 | 09:46 AM
Onyxthecat's Avatar
If you have a decent codescanner it may work but STAR for sure will give you more control.
