E-Class (W211) 2003-2009
Switch or Bulb
Old Sep 11, 2020 | 02:36 PM
ParadiseLV's Avatar
2008 E550
Switch or Bulb
So the other day, I noticed that the illumination for the light switch wasn't working. Do I need to change the switch or is there a way to just change the bulb behind? Any DIY would be helpful.
Old Sep 15, 2020 | 03:41 PM
ParadiseLV's Avatar
2008 E550
Originally Posted by Plutoe
You change the bulb----see WIS for install
How do I get access to the WIS?
Old Sep 15, 2020 | 04:55 PM
konigstiger's Avatar
'71 Pinto
No bulb, LED check connection/pins if it turns out to be switch best to simply replace unless you open and experiment with internals. I believe part # is 2115450104 (should be on switch) shop EBay used for about $20 or so. BTW if you cannot find matching color, face plate can be exchanged.
Old Sep 16, 2020 | 02:52 AM
cetialpha5's Avatar
You can pick up a knock off copy on eBay for about $8.50. It's probably overkill for this situation. The video is probably all you need. The WIS is basically the full dealer repair manual. Comes with EPC which is the parts lookup by vin.
https://www.ebay.com/itm/Latest-2019...n/123679649919
