E-Class (W211) 2003-2009
SBC Error code help
Old Oct 4, 2020 | 08:53 PM
Brianstrange's Avatar
2006 E350
SBC Error code help
I have the following SBC Codes from a scan on a Foxwell NT530:
C249E Under Voltage
C25D9 Check Wheel Brakes
C2534 Hydraulic Fault RF Separator Valve A73Y2
Are any of these connected to the SBC Warranty replacement? I'm assuming that they are older
occurrences, but don't want to reset them if it will null any chance of getting it replaced should that be the solution.
Old Oct 5, 2020 | 09:24 AM
konigstiger's Avatar
'71 Pinto
Could be or have been auxiliary battery (engine compartment) low voltage. SBC is covered for 25 years from in service date, clear codes see if any return. A73Y2 returns, it is internal component have dealer check it under warranty.
Old Oct 5, 2020 | 10:08 AM
2006 E350
Thank you. In my case the Aux battery was recently replaced.
