E-Class (W211) 2003-2009
Grinding/rubbing/clunking when turning at low speeds, $1000 into wrong repairs
Old Oct 5, 2020 | 01:14 PM
Bigtravdawg's Avatar
2007 E550 4MATIC
As the title says, I’ve got a low speed clunking/running/grinding noise at low speeds when the wheel is turned (Backing/pulling into parking stall, navigating parking lots etc.)
The noise comes & goes, & I can’t particularly say when & why it does.
Ex. Went for 1 1/2hr drive yesterday (all highway driving), went to the gas station & circled into the parking stall through the pumps etc, heard it clear as day. 45 minutes later I went to a empty parking lot to get the girlfriend to replicate the noise while I laid down to see if I could hear where it was coming from underneath the car... couldn’t get it to do it.
Previous repairs already include alignment shims, & CV axles on both sides, & no luck. The car was diagnosed by 2 shops & 1 private mechanic. Shop 1 couldn’t find the issue & didn’t have the tools to further inspect, shop 2 did the shims, mechanic did both CV’s.
As far as I’m aware I have no other symptoms. Transmission runs completely fine, shifts normal etc. Drives completely symptom free in a straight line at any speed.
Here’s 2 videos of the issue
Old Oct 5, 2020 | 02:02 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Raise up the rear end, put it in neutral (block the front wheels), and turn one of the rear wheels. Got noise in your differential?
Old Oct 5, 2020 | 03:55 PM
2007 E550 4MATIC
Thanks for your response. Me & my mechanic are gonna put it on jacks here in a few hours & get it up in the air. I will give that a shot & see if we hear anything from the differential
