P0720 Changed conductor plate
I believe it is in safe mode, I only have first and reverse
I'll check with a better scanner later on today to see what module the codes are set in
I was able to get some tcm codes this time:
P2400 - the right rear wheel rpm signal sent from the traction system via the CAN bus is implausible
P2402 - the right front wheel rpm signal sent from the traction system via the CAN bus is implausible
P2430 - the wheel rpms from the traction system are not available on the CAN bus. (CAN timeout fault)
I know the right rear wheel needs a new reluctor ring
im dealing with the same issue but my car is staying in limp mode won’t shift or go over 40 and the SBC red reduced braking power warning is constant
