E-Class (W211) 2003-2009
Anyone know of a DIY thread for power steering fluid flush/reservoir replacement?
Old Mar 14, 2021 | 12:16 PM
Caranas06's Avatar
2006 E500 Airmatic
Need to flush the steering fluid soon. Everyone says replace the reservoir as well but I am struggling to look for resources specific for w211 gas model.
Thank you
Old Mar 14, 2021 | 12:17 PM
tjts1's Avatar
C320
Thank you
all MBs from that era use the same reservoirs and pump.
Old Mar 14, 2021 | 12:19 PM
Caranas06's Avatar
2006 E500 Airmatic
Oh ok, have you come across instructions for replacing the reservoir and flushing the fluid?
Old Mar 14, 2021 | 12:49 PM
tjts1's Avatar
C320
Replacing the reservoirs is really straight forward. Just one hose clamp and one bolt. I don't know about flushing. I replaced my pump and rack a while ago and changed the fluid at the same time. The only reasonable way I see to change the fluid without removing the rack is the drain the reservoir, refill, drive 100 miles, repeat. That will gradually dilluts the old fluid down. You can use a turkey baster or small hand pump to pull fluid out of the reservoir. About 1/3 of the fluid is in the reservoir.
Old Mar 17, 2021 | 02:11 PM
bobgodd's Avatar
2004 E55
I followed this guy's video, worked well. The hardest part was getting the reservoir out and back in, for my car at least.
