E-Class (W211) 2003-2009
Limp mode
Old Mar 28, 2021 | 11:45 PM
Jon boi's Avatar
2003 mercedes benz E320
Limp mode
I have 2003 E320, the car got stick in drive one day with the red battery message on the dash. Got it home used an all systems diagnosis took and got several codes. I replaced main battery, break light switch, conductor plate, and the shifter. After replacing the shifter it came out of drive and it's now able to go through all the gears but crank it up and battery light still comes on and now it is stuck in limp mode. Tried to clear out the code but code 9092 auxiliary battery defective or not installed vibes back, check voltage and drain but battery holds strong at 12.6v. I get 9070 cut off relay faulty 9082 value terminal 15 supplied by control module EZS over there CAN is implausible along with other minor codes. Like 9330,9063,9091,9055, and 9096. Amy one for any ideas what to do next?
