E-Class (W211) 2003-2009
W211 year 2007 SBC Bleed
Old May 28, 2021 | 04:56 AM
MB_user's Avatar
MB220cdi W211
Hi i own W211 2007 and want bleed SBC pump. Is there anyway to do this without Star tool?
Would i be able to do it with star tool C4 without online account... i mean this function is done offline ... RIGHT?
HELP PLEASE.
Old May 28, 2021 | 09:21 AM
tjts1's Avatar
C320
Your 07 doesn't have SBC.
Old May 28, 2021 | 12:32 PM
konigstiger's Avatar
'71 Pinto
See attachment.
File Type: pdf
Old May 28, 2021 | 03:29 PM
MB_user's Avatar
MB220cdi W211
See attachment.
I thought my car has SBC brakes.....I will try to bleed and will reply soon.... THANKS
Old May 28, 2021 | 07:12 PM
tjts1's Avatar
C320
Take a pic of the SBC pump.
Old May 29, 2021 | 02:54 AM
cetialpha5's Avatar
What is the vin and what country are you in?
Old May 29, 2021 | 03:52 AM
MB_user's Avatar
MB220cdi W211
Old May 29, 2021 | 03:55 AM
MB_user's Avatar
MB220cdi W211
WDB2110081B268558..... Norway
Old May 29, 2021 | 03:57 AM
cetialpha5's Avatar
Wow, it's a taxi. No mention of any SBC.
https://www.lastvin.com/vin/5ognYdmeJrVdOzr3W
Old May 29, 2021 | 04:00 AM
MB_user's Avatar
MB220cdi W211
Old May 29, 2021 | 04:05 AM
MB_user's Avatar
MB220cdi W211
It was a taxi...
Procedure for bleeding brakes?
Old May 29, 2021 | 04:27 AM
MB_user's Avatar
MB220cdi W211
A2114312012
Old May 29, 2021 | 04:38 AM
MB_user's Avatar
MB220cdi W211
A2114312012
Old May 29, 2021 | 06:06 AM
MB_user's Avatar
MB220cdi W211
W211 year 2007
What is the procedure for bleeding brakes?... Is it to
depress brake pedal repeatedly and open bleeder screw?
I did start with rear right -left but no fluid is comming out, front is ok.
Old May 30, 2021 | 05:44 AM
MB_user's Avatar
MB220cdi W211
Hi.. have too much air in the system because of rear brake lines replaced.
What is the procedure for bleeding brakes?... Is it to depress brake pedal repeatedly and open bleeder screw?
Old May 30, 2021 | 10:17 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
The pump you show is not sbc
The
The sbc pump has an accumulator.
the bleed procedure should be followed for any normal braking system. If you have run the master cylinder dry, you must bleed that, and same for the abs pump. Lots of info out there depending how dry the system was, but again, from the pics, no sbc. Tools can help in this instance, digital (star) as well as pressurized (brake bleeder)
Old May 30, 2021 | 11:23 AM
'71 Pinto
Here’s your data card. Again, not SBC, see here for bleeding: https://www.pelicanparts.com/techart...e_Bleeding.htm best to use power bleeder.
File Type: pdf
Old May 30, 2021 | 03:01 PM
MB_user's Avatar
MB220cdi W211
Thanks i will try with power bleeder... maybe you can help me with another problem...?
I have continuous currunt to rear left and middle headrest even switch is not depressed. Right rear is working fine. I have disconnected the cable (beside backrest) for the left and center headrest motors. Any suggestions or maybe i need wiring diagram?
Old May 31, 2021 | 12:10 PM
'71 Pinto
Pull f31 @ interior fuse panel (side dash) in an attempt to reset UCP (headrest switch). Problem remains, try disconnecting battery for about 30 minutes in a second attempt to reset. N/G, I believe harness (part # 2115405206) originates from rear SAM in trunk trace harness back and check connector.
File Type: pdf
File Type: pdf
Old Oct 14, 2021 | 06:09 AM
MB_user's Avatar
MB220cdi W211
Old Oct 16, 2021 | 05:32 AM
Senecat's Avatar
1983 Nissan Shltbox
Did you bleed your SBC pump?
Old Oct 16, 2021 | 08:26 AM
MB_user's Avatar
MB220cdi W211
Yes brakes bleeded with power bleeder.. and it worked.
